I was wondering if there are any issues (other than potentially the price) using an enterprise level HDD in a desktop application?  I'm looking at getting a 12-16TB drive to have as my main storage drive (store movies, books, raw photos, etc). I've been looking at the Seagate EXOS SATA drives, but I've never used a drive larger than 4GB in a computer.  I wasn't sure if there are any draw backs or anything I should be aware of.  I'll be running either Windows 10 or 11 (probably 10) on the machine.
https://linustechtips.com/topic/1477309-question-on-enterprise-level-hdds/
Just the cost, but that's partially offset (in my opinion) by the extra-long warranty period. (That said, I shucked external drives for my home server instead of buying new enterprise drives because of the cost.)
As long as it's a SATA drive, there's no reason it won't work. It's going to perform like any other mechanical hard drive.
If it's a SAS drive (Serial Attached SCSI), you will need a SAS controller. Your onboard SATA controller doesn't speak SAS.
Not really. They'll have features you're unlikely to use, but that's about it, most other differences are benefits, such as the longer warranty and lifespan. They can sometimes be a bit louder than desktop drives, as noise isn't really a problem in the datacentre.
Not at all. Much better than your typical consumer grade drive.
Do make sure your case has proper vibration reduction and good mounting for the drive, though.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
4GB... what are you running... windows 3.11?
as they already said here... a datacenter is noisy... generaly generated by fans and disks. you get disks from 15000rpm and down. if anyone complained about coilwhine here from GPU's and PSU's... it's nothing compared to the constant noise faster enterprice disks makes.
and for the controller you will need for SAS disks that they all are. is it realy worth it?
If you want larger storage i suggest you look at NAS disks cabinets you can store somewhere noise isn't a problem. and access it over the network.
you get sata NAS disks up to 20TB ... those are usually set up with some redundancy, like RAID 5.. so you need 3 disks minimum..  or a mirror with 2 disks, raid 1.. basicaly a copy, but not expandable.
and you can buy just 1 and put it in your case...  but if it crashes the data is lost. some bios's even support raids 0 1 5 .. so you can mount more than one disk. alto the noise will be more..
