A need for two different CPU coolers...difficulty inside
Two different systems:
A DeskMeet x300 with a Ryzen 5 5600g. Using stock wrait, but even modest gaming gets it to 90+. Difficulty: Cooler can't be taller than 54mm. Suggestions?
A Chinese salvage mATX Haswell 2011-3 Xeon board, need a horizontally blowing CPU cooler (I'd like the excess air to cool the VRMs near the CPU)
mobo listing is here:
https://www.aliexpress.us/item/3256801445368152.html?gatewayAdapt=glo2usa4itemAdapt&_randl_shipto=US
Suggestions?
MACHINIST-X99-K9-X99-Motherboard-LGA-201
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
12 minutes ago, aDoomGuy said:
Pure Rock 2
That's vertical...not horizontal (unless Google is deceiving me)
6 minutes ago, aDoomGuy said:
You want it to blow like a stock cooler? I'm getting confused. 😄
I need the cooler to blow horizontally (I believe I mentioned this in the original post) to it'll cool the VRMs as well.
The thing is, when you have the mobo vertical then it will blow horizontally regardless, right?  My Dark Rock blows horizontally....
How about Noctua LH-12S? If you want it to blow towards the mobo like a stock cooler.
 If you want to cool the motherboard well, what you're looking for is a downdraft cooler that blows air down towards the motherboard.
What case are you using? Have you tried undervolting?
Probably an open frame PC case...but currently undecided.
No interest in playing with OCing/UCing.
The AXP90-X47 should be a decent upgrade from the stock cooler: https://pcpartpicker.com/product/VmTp99/thermalright-axp90-x47-4258-cfm-cpu-cooler-axp90-x47
For 2011-3, the BIG Shuriken 3 Rev. B works as a downdraft option: https://pcpartpicker.com/product/kykwrH/noctua-nh-c14s-8252-cfm-cpu-cooler-nh-c14s
If you have more to spend, the NH-C14S or Dark Rock TF 2 are better:
https://pcpartpicker.com/product/GTpzK8/be-quiet-dark-rock-tf-2-cpu-cooler-bk031
8 hours ago, WoodenMarker said:
AXP90-X47
That looks like just what the doc ordered. I dunno why it didn't show up in my searches tho. Well, this is what I come to LTT for, your help. Thank you!
