5800X3D temps inquiry
Go to solution Solved by Dr. Will0hlep,
So, the wraith max was designed to work on CPUs with a TDP of 95W or less. The 5800X3D has a TDP of 105W.
Now:
1) cooler TDPs are a bad measure so take the rest of what I say with a pinch of salt
2) modern CPUs will deal with whatever cooling you give them (so long as you give them something), they'll just slow down to avoid overheating (this means it will work fine and shouldn't be an issue but you might leave some performance on the table)
I'd recommend a better air cooler but I don't believe you need it
Hi all!
Long time hardware enthusiast but first time tinkerer.
I have a pre-built system that had a 3700x in it and went and got myself a 5800X3D as an upgrade. I've gone a head and put the new CPU in myself and am a bit concerned about temps. The CPU temp @ idle is around 47C-48C and under load (R23/games etc) it jumps and hangs right at 90C. I do understand that the 5000 series is designed to operate at up to 90C but I'm just nudging up over the limit at 90.4C. I'm wondering if maybe I should go in an re-apply the thermal paste to try and get better results.
Currently I run with a Wraith Max cooler and I leave the case window open.  Any thoughts? Is this just kind of "how it is now?" or short of getting a new cooling solution, is there some additional things I can do to get that max temp below 90C with the current set up I have? I've attached a copy of the HWiNFO readout right after running R23 Multi in case that tells anyone anything.
Thanks!
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/
Now:
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need. Expand this signature for common PC building advice, a short bio and a list of my components.
Common build advice:
1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticeably improve performance past 240mm and don't improve at all past 360mm. 9) RTFM.
Useful Websites:
https://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
Bio:
He/Him - I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 4 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). Aside from computers, I also dabble in modding/homebrew retro consoles, support Southampton FC, and enjoy Scuba Diving and Skiing.
Fun Facts
1) When I was 3 years old my favourite toy was a scientific calculator. 2) My father is a British Champion ploughman in the Vintage Hydraulic Class. 3) On Speedrun.com, I'm the world record holder for the Dream Bobsleigh event on Mario & Sonic at the Olympic Winter Games 2010.
My Favourite Games: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii, Balatro
My Computers: Primary: My main gaming rig - https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C Second: Hosts Discord bots as well as a Minecraft and Ark server, and also serves as a reinforcement learning sand box - https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P NAS: TrueNAS Scale NAS hosting SMB shares, DDNS updater, pi-hole, and a Jellyfin server - https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C Foldatron: My folding@home and BOINC rig (partially donated to me by Folding Team Leader GOTSpectrum) - Mobile: Mini-ITX gaming rig for when I'm away from home -
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/#findComment-15719529
The 5800X3D is especially prone to running hot due to the extra thermal interface used (essentially a silicon shim between the cores and IHS). It's one of the presumed reasons AMD disabled overclocking on the chip.
That being said, it's not thermal throttling, so just leave it be.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/#findComment-15719539
Actually that is way into throttle territory and it's *not* designed this way at all for normal operation...
90c is still safe, but that will not get better over time and it won't operate at maximum/  ideal performance either.
It's really easy: you need a better cooler,  all the advantages of the 3D vanish when it's throttling.
For comparison my 3D has 79c max running cinebench multi
it actually is
1473936877_Screenshot_20221227-050213_SamsungInternetBeta.thumb.png.006816050807f5a225ed9cf34b684f3a.png
it starts throttling at 85c straight...
idk why hwinfo64 says "no" thats entirely not correct however,  maybe it's an older version
-Scott Manley, 2021
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/#findComment-15719863
In R23 Multi? Mine hits 71 with no fans on the cooler in a stock Torrent Compact config.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/#findComment-15719866
but you live in Antarctica and do voodoo to the thermal paste, its not fair!
-Scott Manley, 2021
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/#findComment-15719868
Lol it is 19c in my space right now 🙃
https://linustechtips.com/topic/1476609-5800x3d-temps-inquiry/#findComment-15719876
