no post after enabling XMP
Solved by RONOTHAN##,
The 3200G likely won't enable XMP because 3600MT/s is very aggressive for a 3200G. Those chips struggle to go above 3200MT/s, let alone 3600MT/s, especially on a low end motherboard. Enable XMP and start lowering the memory frequency until it starts POSTing, then make sure to check for stability. You can also try setting the SOC voltage to 1.15V, that can help with memory overclocking and should be safe for long term use, though don't expect that to make a monster of a difference, maybe 100MT/s at most.
