Hi Guys ,
I am new at this comunity but not new in computer hardware and software.
I have strange problem with  them, all of them are brand new and all of them are spining fan but no displaying anything . I was checking all voltages , everything is fine but no picture on any port.
I susspect on bios but maybe here someone has more expirience with this issue . Also to mention that I have tried on both bios on all cards same problem. I do have programer for bios so I can reprogram but maybe someone has other solution , or had this problem and knows how to fix it. They are not  in warranty anymore so returning to store is not possible.
Any help is very appreciated
Thank You guys
https://linustechtips.com/topic/1475642-xfx-rx580-problems/
40 minutes ago, Mixa990 said:
Hi Guys ,
Thank You guys
If none of the cards work, your issue is probably with the cpu or motherboard or your psu is not powerful enough. I doubt all of the cards would be defective, however that is a possbility if they were connected to the same computer previously.
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15712859
What’s your test bench specs?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15712906
1 minute ago, Mixa990 said:
My testbench specs are :
Motherboard : B450MH Ver 6
CPU: AMD Ryzen 5 5600X
RAM: 16GB Corsair 2x8Gb at 3200MHz
PSU : CoolerMaster MWE 750 BRONZE V2
Are you using any adapters from your variable PSU or are you powering these graphics cards with only the CoolerMaster? Your display is plugged into the graphics card and not the motherboard right? (have to ask)
Are you able to upload a picture of one of them on your test bench so we can see how everything is hooked up?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713426
I also have my old pc running that same XFX RX 580 8Gb Black edition card in :
CPU : AMD FX 6300 black edition
RAM: 16 GB Fury red 4x4GB
PSU : 700W CoolerMaster MWE700 White
SSD: 240Gb Samsung Evo
Motherboard: Asus M5A99FX PRO
And it works just fine in this configuration.
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713457
I am using just my PSU , and tried to use Display ports and DVI ports on my graphics card , nothing happens . Card is running , the fans spin for 1 minute and then stops but card is running still, I have 900mV on Display rail ,also have correct voltage on GPU side but no picture, enable is ok , all voltage rails are ok , all memory is ok, just no displaying anything on output.
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713481
Just now, Mixa990 said:
I am using just my PSU , and tryed to use Display ports and DVI ports on my graphics card , nothing happens . Card is running , the fans spin for 1 minute and then stops but card is running still, I have 900mV on Display rail ,also have correct voltage on GPU side but no picture, enable is ok , all voltage rails are ok , all memory is ok, just no displaying anything on output.
Does your test bench work with other graphics cards? My first instinct is that these cards work in your other computer so there's nothing wrong with them, but you have a 5600x on a B450 motherboard.
Did you update the BIOS of that motherboard to support the 5600x?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713484
I asume that maybe someone played with bios and bricked the card. I do have a CH341A programer so I can try to reflash it but just need advice if someone had this issue
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713488
I have my own old graphics card , that is ok and it works in my old PC , I did try all of this rest cards and they do not work.
The bios was updated so it should work , I tryed with some card which has some other problem (vram bank) , has corrupted screen image 2 lines , same XFX RX580 8Gb and it works , displays the picture on all outputs , so this all cards should work fine in point of compatibility .
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713505
Yeah myb you need to use another bios.. For me, i'm using new bios and work well with uefi bios but when i switch to csm my card wont boot just black screen.. i mean my card boot with no driver, but when i installed drivers that happends.. so it could be it? Did you try to switch bios?
Did you get any pic like to get in bios or if you have igpu put card in but boot with igpu and see if system rec them
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713553
Okay, I think I get it now.
I thought they were all new. They're broken and you're wanting to repair them?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713572
They are new, just tried and not displayed picture, then put back in box and left that way for 1 year, now I got them and want to try to fix them.
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713754
Does Windows detect them and there's no video out, or are they just flat not detected?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713759
1 hour ago, Mixa990 said:
I will check that tomorrow because I haven't tried to put 2 cards to see if it is detected. Now it is flat black
Copy.
Check your linear converters as well. Also, some XFX 580 cards had issues with ground channeling. With the card plugged in, check to make sure you don't have voltage on any of your grounds.
Voltages coming off the PCIE slot, 5v readings, 1.8v, display rail voltage, MVDD, VDDCI and your core voltages if you can. And resistances for 1.8, 3.3, 12v and display. They'd require the cooler coming off though.
I'm at work(my normal job) so I don't have access to my boardviewer schematics, but IIRC there's also some issues with the U100 ICs they were using. It's a 6 prong gate.
This is what I was able to get from image searches.
If for some reason board viewer files are needed, I can see if my fiancee can jump on my computer and get them sent to me.
I would have returned these a year ago if they were brand new btw.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15713809
5 hours ago, IkeaGnome said:
Copy.
I would also returned them if they were at my place 🙂
but these cards are from my friend who gave this to me couple of days ago. If I knew this before it would be different. But they are gift , this is just part of them , there is 26 cards same with same problem and one XFX RX580 FatBoy with vram problem. I would like to repair them, at least to try to fix them. Not a crypto miner just enthusiast . Don't want to sell them either rather to give them as a gift to someone in Serbia who needs and can't afford to buy any. Also maybe to build some pc because I have more than 30 different PC which are repaired and mainly don't have graphics cards. So this is like humanitarian repair no charge at all . I am expirienced with electronics but actualy never repaired graphics cards before.
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15714091
So I'm not sure if I've got the XFX 580 diagram in this. My folder names got entirely borked on me. I know it's one of these, but I can't remember for sure which it is.
However, I think this one is the XFX 580. It looks very close. Looks like I'm stuck going through and renaming files when I get home..
Were the cards detected by Windows or no? That'll change what we start chasing down. If they weren't detected, what are your power readings on both sides of these chips?
That's the start of your display rail. If you have a converter not working right, the rail won't kick on and the card will be undetected/no video out.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15714694
  Hide contents
  Hide contents
I have voltage on the display, on VDDCI on VRam contoler also on gpu side but no display output, I will try with Gigabyte B450M DS3H motherboard, Ryzen 7 cpu and here it has 2 slots for gpu so i can try to see if it is detected.
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15715072
How much voltage? You can get voltage, but not have enough.
Being detected or not changes what we'll want to look at.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15715076
3 minutes ago, Mixa990 said:
I have 900mV on display rail also 900mV on gpu side
That's a tiny bit low, but nothing horrible. Should be closer to 950 on the display rail.
Was the card detected in Windows?
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1475642-xfx-rx580-problems/#findComment-15715126
