Air pressure
Solved by Sarra,
If you want positive pressure, set your exhaust fans to a lower RPM than the intake fans.
I have my motherboard set to match my intake fans with my CPU fans, which does kinda suck when gaming since my GPU gets hotter, though not quite enough to make that much difference.
I wish I had a fan header on my GPU, I could run my lower front intake fan off the header and have my GPU control that fan, leaving the top fan to match my CPU, giving me a better, overall, cooling solution.
I don't have an exhaust fan anymore, my CPU cooler is so close to the rear of my case, it's basically an exhaust fan all on it's own. Plus, there's no more room for another fan back there...
