Nvidia RTX 4080 low fps problems
Go to solution Solved by DoctorNick,
15 minutes ago, SimplyChunk said:
IIRC the 9700k was basically and 9900k with the hyperthreading disabled right?  So moving to a 9900k will give OP about a 70% increase in performance?
You won't see a 70% difference. Most games doesn't scale with HT very well. Also if OP is getting 1440p display = less cpu bottleneck and even less of a difference going to 9900k.
@ZazaMaza123Get a 1440p display first. See how it runs. If you can get good offer on a 9900k, you can get that but don't pay too much. Then you'll be better off saving for a new CPU, motherboard and ram depending on what you choose.
So i recently upgraded from 2060 super to a 4080 16 gb . Bought a new 850 W 80+ platinum supply for it . Booted with the new card , installed the latese nvidia driver ( used the clean install to uninstall the old driver files and cofing) .
Booted later Cod Warzone 2 , video setting i made them competitive for more fps and the most iam getting is 120 fps , in gulag only it goes to 160 +. Playing in 1080p resolution 144 hz monitor . Tried also for the game to optimize it self , and it put everything to ultra it runs but like its not utilizing the card . The game runs perfectly smooth as compared to older card and more vibrant collort .. What could be the problem or is the card to strong
My pc specs are :
asus prime z390-p motherboard
core i7-9700 3.00ghz
Ram: 2x8 gb dual chanel memory with xmp profile to 3000 MZh
Nvme ssd Samsung 860
CORSAIR TX-M Series TX850M
https://linustechtips.com/topic/1474321-nvidia-rtx-4080-low-fps-problems/
You are severely bottlenecked at 1080p with your combo GPU/CPU.
Almost all highend GPU's are bottlenecked by the CPU at 1080P.
My Rig: CPU : 10700K | RAM : Trident Z Neo 3600Mhz c16 32G (4x8) | CPU cooler : NHD15 | GPU : ASUS ProArt 4070 | PSU : Corsair RM850 (black label) | CASE : Corsair 5000D Airflow | Storage : Samsung 970 evo 1TB, WD Black 1TB, Samsung evo 850 Sata SSD | Casefans : Lian Li Unifan SL120 7X|
MOUSE : G Pro Wireless X superlight | Keyboard : Keychron C1- Pro-H1 Gateron Milky Reds
@Alinz is right.  Your frame rate is being limited by the CPU.  High refresh rate gaming is more dependent on the CPU than the GPU
Edited by SimplyChunk
spelling
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
Get a 9900k if you can and switch to a 1440p high refreshrate display is my advice.
The 9900k is still a great CPU, and I think will be for some time to come, especially at higher resolution gaming.
Ok so that's the problem . Do you think i need to also do some overlcoking on the cpu for it to handle it
Yes, basicly. The 9900k also has a slighly higher boost clock.
Id suggest running it stock first and see what kind of performance you get. Tinkering with it is something you can always do later
Hot chip.  Hot, hot, hot chip the 9900k.  So only if you got the cooling
added review
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
You seem to know the stuff , tnx for explaining  . i might the the display first as for the other parts , i plan to buy something new every month so hopefuly it will be complete . If you have any suggestions for the cpu ( intel preferably ) and motherboard combo let me know
Just bear in mind OP that your frame rate will not increase moving to a 1440p display.  Which is what your original inquiry was for.  If your CPU can only push 120fps at 1080p then it's not gonna start pushing 140+ at 1440p.  You can even test this before you buy anything by enabling DLDSR in the control panel and selecting the higher resolutions this will make available in game menus.
typo and context
PCPartPicker Part List: https://pcpartpicker.com/list/CM24jZ
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor  ($319.97 @ Newegg)
Motherboard: MSI PRO Z790-P WIFI DDR4 ATX LGA1700 Motherboard  ($229.99 @ Newegg)
Total: $549.96
Generated by PCPartPicker 2022-12-16 07:08 EST-0500
This board uses ddr4. then you can save on that and get a new ssd instead
Gaming PC:
Linux PC:
Total: $549.96
Thanks man .god bless you .
Total: $549.96
So I am also having issues with lower than expected FPS with my new build. I thought I would easily get 200+ FPS on 1080p/144hz. But I am only averaging about 160. What gives? Some say I am bottlenecking cause of my RAM, but I can't find a true consensus.
My specs are:
  • CPU:Intel Core i7-12700KF 12-Core 3.60 GHz
  • GPU:GeForce® RTX™ 4080
  • RAM:Team T-FORCE Delta RGB 3200 MHz 32 GB XMP 2.0 Enabled.
  • Storage:Western Digital Blue SN570 NVMe M.2 SSD 1 TB
  • PSU: XPG Core Reactor, 850W, 80+ Gold
My specs are:
What games are you playing?
16 hours ago, tomtendo said:
Following up on this. I am playing Warzone 2.
Me too, I just got a new Rtx 4080 and I don't see much of a change about the FPS, with my RTX 3070 I was getting around 120 average fps and now I am getting 135....
I am playing @1440 p
CPU: Intel Core i7-10700KF 8-Core 3.80 GHz
GPU: GeForce® RTX™ 4080
RAM: 32.0GB Dual-Channel unknown @ 1463Mhz (14-18-18-32)
XMP 2.0 Enabled.
Storage: 953 GB INTEL SSD
PSU: CB 1050 W
( all the info I got it from speccy)
I really need help because I don't know what I am doing wrong or what do I need to update. I feel kinda bad for spending a lot of money on a new card and not getting any improvement.
Thanks for your time guys.
XMP 2.0 Enabled.
PSU: CB 1050 W
Well i can tell you now it'll be your CPU in this instance.  Maximum frame rate is determined but your CPU more than your GPU.  If you lower your settings to 720p or something similar and the frame rate doesn't increase.  then you know your binding factor is your CPU
My specs are:
Also, you could do this to test.  lower your setting to 720p and see if the framerate increases.  if it doesn't you know you're hitting your maximum CPU framerate cap
Hi, i just did the test and here are the results:
720p: max FPS 150 and the Gpu is only being use 40 - 45 % average
1440: max FPS 150 and the Gpu in only being use 55 - 60 % average
I did the benchmark test for call of duty and I got those results.
The test says  i get 205 fps average but I am not seeing that or even close in Warzone.
What should I do next? buy a new Cpu and a new motherboard? or do i have other options.
-snip
If you want more frames your only option is a CPU upgrade.  Warzone 1.0 always was more heavy on the CPU that MW.  So i'm guessing that'll carry over to Warzone 2.0 and MW2
Do you have your render resolution purposely set to 57% ? That will bottleneck the heck out of your cpu
How'd you get the 3rd screenshot showing benchmark?
