I need help ASAP
Solved by Mark Kaine,
14 minutes ago, SomeoneKnown said:
yeah that "looks" a little high, but around 40-50 is really normal on air, and its a bit warmer in Mauritius (?) as u said, 30c, its 17c in my room for example...
and some intels run hot anyways... all u can do is set a higher fancurve or get a *good* aio (expensive)... imo thats nothing to worry about as long it works ok otherwise.
ps: and yeah, *if* it starts throttling (u can see it hwinfo64) during load, then you have to think about a solution... turning off turbo boost may be also an option.
