No exhaust fan. Is it okay?
Solved by Dukesilver27-,
Just now, sergo said:I can move it at the back but it would be a pain to get to it right now and it would be easier to just get another one for the back tomorrow. So I'm not sure if I should leave it as it is or just get another one tomorrow.
Well, if it is temporary, sure it is fine. It's just the air would be circulating in the case untill they find a way out. Maybe lower boost performance for the CPU and higher temps for the GPU, which is fine for short term.
