Hey guys I hope everyone is doing okay
I have a 3080 MSI VENTUS X3 and a ryzen 7 5700x and 16gb ram 3200mhz.
today, I plug my motherboard ( B550-F asus rog strix ) and a new m2 ssd adata s11 pro.
as soon as I turned the pc I got this picture, Idk what that means but I hope it's from the cooler that I have ( coolermaster g100m )  hopefully it is the issue because I'm getting a new coolermaster ML240 watercooling.
Also my cpu temp ingame is 86 degree
can anyone explain the picture and confirm that's from the cooler?
thanks!
also my pc is SOOOOOO LOUD, I had a ryzen 5 3600 and it was quiter than that, much quite even in games... now when I'm in my desktop it's screaming
Edited by SouSkrt
https://linustechtips.com/topic/1469852-cooler-issue/
Your cooler is not plugged into the motherboard's CPU Fan header to sense the RPM... would be my guess.
Intel Core i9 10920x CPU; ASUS ROG Strix x299-E Gaming II Motherboard; 64 GB Corsair Vengeance LPX DDR4 3200 MHz Quad Channel Kit; EVGA RTX 3070 XC3 ULTRA Gaming 8 GB; 2 TB Samsung 970 EVO Plus NVMe m.2 SSD & 1 TB Samsung 970 EVO Plus NVMe m.2 SSD; 1 TB WD Blue SATA SSD; 2x 6 TB HGST DeskStar NAS Hard Drives; Corsair iCUE H150i RGB PRO XT All In One Cooler; Corsair RM1000x 1000 Watt PSU; Corsair Commander Pro Lighting & Fan control; 4x Corsair HD120 RGB 120 mm fans - Intake ; Lian Li 011-Dynamic Razer Edition cube case, Windows 11 Pro 24H2
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671641
Just now, SouSkrt said:
it is rotating, you mean it's plugged in the wrong slot?
Possibly... the lead for the fan (or RPM sense wire pinned with a 3 or 4 pin fan plug) is plugged into a different fan header than CPU Fan.
The motherboard usually requires a Fan RPM signal not to get that error msg.
CPU coolers (not familiar with your model) have a Fan lead or RPM sensor wire lead that goes to the CPU Fan header on the motherboard...
Hope this helps...
Believe me I have a complicated setup with a Corsair Hydro H115i AIO cooler and a Corsair Commander Pro... took a bit to get mine all sorted
BlackDragon
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671657
Hope this helps...
BlackDragon
Let me go ahead and change the slot of the cooler pin, I'll keep you updated.
brb
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671658
Hope this helps...
BlackDragon
Nope, nothing changed.
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671668
hmmm... that usually fixes the problem
 What's plugged into the CPU Fan Header on your motherboard?.... Try a regular case fan lead and see if the error goes away...
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671669
I'm not familiar with the hardware setup and am speaking in general...
Anyone got any other idea to resolve the issue ?
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671674
I do not have another fan unfortunately
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671681
that's where you phone your buddy who knows computers more than you... ask him / her to bring a case fan and offer them a beer....
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671689
That sounds good, It's late now, ama do it tomorrow, I'll keep you updated.
https://linustechtips.com/topic/1469852-cooler-issue/#findComment-15671691
