I just got daylight from XTankSlayerX's give away
Whenever i try to launch the game i get this error message, how do i fix it ?
Thanks
CPUIntel 4670k  Motherboard - Gigabyte GA-Z87X-D3H  RAMKingston HyperX 8GB  GPU - EVGA 780  Case - Fractal Design Define R4    Storage - 2TB WD Black, Samsung 840 Evo 128GB     PSU - Corsair RM650  Display -  Benq XL2430T and Acer S235HL  Cooling - CM Hyper 212 Evo  Keyboard - Corsair K95  Mouse - Razer Deathadder  Sound - Sennheiser HD 558                                 Mic - Blue Snowball  Phone- OnePlus One  Tablet - Nvidia Shield
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/
i get the same error from what ive seen about it i havent bothered to fix it.
Listen if you care.
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961496
Re-install the games, it likely got corrupted and files obviously went missingI have
I have, twice to my HDD and twice to my SSD
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961498
WOW, so they released a game that doesn't launch ?
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961503
Install it to a custom folder and see if that works, could be simply a bad port.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961550
I have
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961553
Going to roll back to an older version, people are having the same problem just after the patch
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961612
It's fixed, i just used an older version
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1961645
Thanks
just an FYI it's not a good game. might as well play outlast, its a way better daylight.
(sneezes) "Sorry I'm allergic to bullshit"
https://linustechtips.com/topic/146890-emmmm-help-with-daylight/#findComment-1965066
