Best Way to Backing up OneDrive for Business Data
26 minutes ago, DrMacintosh said:Currently, there is no method (that I am aware of) of incrementally backing up OneDrive/SharePoint data.
Backup software does this, just have to decide if you are prepared to pay for such a supported product.
Software wise Veeam does a great job at Office 365 backups, I use Commvault however that can be a little more complicated to setup. There are other options in the market.
Anyway Office 365 supports APIs to gather changed data between last backup, between time frames, so you can do incremental backups.
Currently we backup to on-prem storage:
- 200TB of OneDrive
- 41TB SharePoint Online
- 54TB Exchange Online
Your data sizes are small so this won't be too much of a problem for you however just so you are aware Microsoft have very strict egress QoS so getting data out is a challenge. All backup software manage this using multiple "Applications" or Service Accounts as the QoS rules are per these so to increase the egress data rates you have to scale these out and round robin between them, again backup software will manage this process automatically once setup as per their documentation etc. I don't expect this to be a problem for you.
26 minutes ago, DrMacintosh said:While OneDrive/SharePoint offer many tools for recovering data and allegedly have good backup systems, that does not help us if OneDrive goes down or we can't access it for whatever reason.
Their systems are only good for availability and not backup and data retention. Been hit with OneDrive bug in the past where user OneDrive just went blank, no data and nothing in Microsoft's delete items retention either. Put in place legal hold for 2 years across the tenant which helps when it happened again but to actually restore all the data was a pain in the ass and required PowerShell script to get it done, web interface and manually select files is not sufficient for thousands of files.
Basically the service is great, data protection overall is good but if it goes wrong recoverability options are not great when it fall outside of the normal expected problems.
26 minutes ago, DrMacintosh said:When do LTO tape drives start to make sense?
Only when you have backup requirement that will use many tapes per retention point, aka not your situation. Use a archival cloud solution.
Cloud to Cloud data protection offers a really good balance and satisfies moving the data off platform protecting you from platform issues.
26 minutes ago, DrMacintosh said:Boss won't be happy about the bill for a project like this, but as the company grows in the future this becomes serious and I'd like to have that security.
The per user pricing of backup software for Office 365 is surprisingly good so don't pass these up as an option if you assume it will be too costly. They'll also save you a ton of time and use storage space more efficiently along with scaling better with growth. They will also allow you to configure multiple data retention copies so you can have data locally and data moved in to a cloud archive provider
