What's up community!
I'm specking out my first pc build and I need help with deciding whether to do a Small Form Factor build. Right now, my biggest decider is whether to use an ITX motherboard or not. Is that smart? Is ITX a good option for by first pc?
I could use the help. Thanks!
(Btw, I haven't fully decided, but my pc will be either 12th gen Intel or recent Ryzen 5, and hopefully a 3060)
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/
ITX can really limit your options if you are air cooling and personally I do not trust water cooling, they just don't last as long and in the unlikely event it leaks the damage is so much worse than air cooling where your system will just throttle or shut down.
I was ITX for many years but moved back to towers as its so much easier to build quiet ones at larger sizes, watercooling is pretty much mandatory to make a quiet ITX build.
There's also the fact ITX is more fiddly to build in general, so probably not ideal for a first build.
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15660789
SFF builds are usually more expensive than comparable mATX, harder to build in, and less upgradability.
Judging by your chosen parts, I'd advise against it.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15660795
I would avoid ITX if u plan on upgrades or putting it in a hot room.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15660796
What's your reason for wanting to go ITX?
I built my first truly ITX system last year. It was fun, but a little challenging and greatly reduced the list of parts I had to choose from. It's also quite loud due to air flow restrictions. If you plan on putting your PC on your desk, ITX is the way to go, but I don't think I'll make another ITX system (I also don't mind just having my tower sitting on the floor). It's also a pain if you ever need to change something out. My next PC will definitely be a full tower.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15660802
Thanks. I am interested in ITX and SFF for the smaller footprint on my desk and such. I am feeling open for either though.
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15660813
I don't agree with a lot of what's been said as if done correctly, ITX systems can be incredibly compact, power dense, quiet and reliable. The problem for new builders is just not having the experience to do SFF well or underestimating the increased cost. My suggestion is to first head over to reddit.com/r/sffpc and see what people are doing. I ran a 5800x/3090 in a Meshlicious for two years just fine, super quiet and incredibly powerful.
Its certainly not for everyone but if you have no use for expansion cards it's a real fun subset of the PC building hobby. Something about power density is incredibly appealing so some, not all.
Join us.
..just to get you excited..
83sv6gn1r4x91.jpg?width=4032&format=pjpg&auto=webp&s=02021e5bda3254cc9e04ad7c601e16134a8c1b1e
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15660828
it used to be that ITX was much more expensive but not so much these days. You have cases like the nr200 and the SAMA IM01(this can accommodate an MATX) which are not expensive.
I had an easier time building in my nr200 because it was really compact and there isn't much to lug around. Of course the complexity here is to make sure that all your components can fit.
You also have  really good compact dual tower coolers like the thermalright silversoul 135.
Maybe a good starting point for you would be the SAMA IM01/IM02 since those can accommodate matx motherboards and 4slot GPUs.
img_20210120_213202-jpg.378548
h52xtfnkq7p71.jpg?width=640&crop=smart&a
With the mesh side panel, it can fit really good performing coolers.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
https://linustechtips.com/topic/1468288-first-pc-itx-or-not/#findComment-15661246
