So I have a few questions I need help with.
This one (probs easy, just don't know it off the top of my head):
Find the Area
And also can someone check if my working is correct and I have the correct answer in the end (my diagram isn't great, mainly for the pro-numerals).
Find the radius of the smaller circle, if the radius of the bigger circle is 1.
Working:
OC=√2r
OA=1
OC+CA=1
√2r+r=1
r(√2+1)=1
r=1/1+√2
r=√2-1 which is around about equal to 0.414213
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/146692-help-with-maths/
my guessing is that the first one probably just is half of a circle with a radius of 8 cm. (you have to take the part below the x axis and put it in the hole above it)
please correct me if i'm wrong
edit:
-since you are 15 years (according to your profile) you should be able to complete the first one now
-i am guessing you have to calculate "r" in the second question (the radius of the smal circle)?
Edited by darkspeedy26
build log: diagonalmod (RIP?)
i know i use many of these: ( ) and these: ... (i really do... (sry...) ) edit: and edits
https://linustechtips.com/topic/146692-help-with-maths/#findComment-1958905
edit:
Yes, you have to caculate the radius of the smaller circle, I edited it in.
The first one you just use Pie x Radius² and then half it cause its a semi circle
@Almercenary
Yeah, got it now, thanks, welll I atleast got the same answer as my buddy so should be all good.
https://linustechtips.com/topic/146692-help-with-maths/#findComment-1958952
Find the Area
I got 12.56 for that [(3.14*8)/2]
as for the other one, I'll try it later when I get home if someone hasn't already tried it.
edit: some things that I got:
A=(0.71,0.71)
C=(0.415,0.415)
D=(0.415, 0)
R=0.415
2R=0.83
Woo!
https://linustechtips.com/topic/146692-help-with-maths/#findComment-1959060
h. is just half the area of a circle at a radius of 8 (or diameter of 16).
The inverted and protruding semicircle cancel each other out.
A = pi x r^2
So...
pi x 8^2
therefore
A = 201.06
Half that and you get...
100.53
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/146692-help-with-maths/#findComment-1959105
A=(0.71,0.71)
C=(0.415,0.415)
D=(0.415, 0)
R=0.415
2R=0.83
For 1st one wouldn't it be this because it's area.
π*8^2=64π
64π/2=32π
32π=100.531
rounding is hard :D
0.414213 is wrong, 0,414214
Im tired, cut me some slack  :D
Thanks!!!
https://linustechtips.com/topic/146692-help-with-maths/#findComment-1959107
A = pi x r^2
So...
pi x 8^2
therefore
A = 201.06
Halved, because it's a semi circle.
https://linustechtips.com/topic/146692-help-with-maths/#findComment-1959111
