Hey guys, so I got my loop up and running, and there's a leak somewhere. Every time I come check on it, there's a small puddle on top of the power supply/pump stand, but no water trail, or leaks that I can see.
So I have a FrozenQ reservoir, connected to a Swiftech MCP655, with a Bitspower mod kit and top, with a male to male fitting. Any ideas where it could be coming from?
Here's some pics
http://i.imgur.com/DgeUFQj.jpg
http://i.imgur.com/1apZnJI.jpg
More pics
http://i.imgur.com/HLCOGuQ.jpg
http://i.imgur.com/dvJW8QB.jpg
https://linustechtips.com/topic/146564-leak-location/
Here's some pics
http://imgur.com/a/CdMvm#94
http://imgur.com/a/CdMvm#99
"SOME" pics god lord i dont wanna know what alot is.
https://linustechtips.com/topic/146564-leak-location/#findComment-1957279
Graphics card or the res.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/146564-leak-location/#findComment-1957288
I've wrapped napkins around all the fittings before, and the graphics card fittings are fine. If it's the res, I have no idea which one it's coming from, since there's 3 fittings and 5 plugs and I can't see a water trail
Sometimes it's best to take it all apart and try again.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/146564-leak-location/#findComment-1957332
Sigh, I'll keep that as a last resort. It was a pain getting in there to tighten all those fittings. Could it be the pump and the top not making a good seal?
It's entirely possible.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/146564-leak-location/#findComment-1957385
if the ress is more than 1 solid part i bet that some of the fittings or seals are broken
https://linustechtips.com/topic/146564-leak-location/#findComment-1957433
The res has leaked before from the caps, and it's definitely not coming from there. The only way water from the res could end up on the PSU is if the bottom stop fitting is leaking (unlikely since it overhangs the PSU and it'd end up on the case floor, not the power supply) or the male to male fitting.
https://linustechtips.com/topic/146564-leak-location/#findComment-1957638
well there you have it MALE TO MALE does not work hue. guess u gotta rebuilt it :)
i always assemble mine in the bathtub and run air through it before i fit it in the pc
https://linustechtips.com/topic/146564-leak-location/#findComment-1957924
I've stuck a napkin around that for the time being and I'll check up on it once in a while. If it's not that, what else could it be?
wowzerz! That's some close-up shots there bud ;). I gather you've made sure that excess ports on the pump/res combo have been tightened properly and the fittings have an O-ring on them? Also don't over tighten the fittings because you'll push the O-ring out of shape, they should be only hand tightened.
Perhaps make sure aswell that the res is screwed in tightly. The fitting that joins the pump and res together looks really suss to me.
Wanted to make sure you guys could all see. ;) Yep, I've wrapped napkins around all the fittings and they're fine, so I think it's the res/pump. Although if I screw it in any more, I don't think that one fitting will hold up a res full of water....
https://linustechtips.com/topic/146564-leak-location/#findComment-1958035
I tested it for one more day with napkins all around the male to male fitting. No leaks there, but there's another puddle on the pump stand thing. The only thing down there is the pump top. I don't think it's coming from the stop plug, so could there be a crack somewhere?
https://linustechtips.com/topic/146564-leak-location/#findComment-1963463
i was cracking a joke about male to male as in nevermind. but yeah. it might be a crack, if you cant find the lead i would assemble it outside and put it in the hot tub or a bucket and see where the air bubbles comes from
https://linustechtips.com/topic/146564-leak-location/#findComment-1963521
Wow I'm slow. Didn't notice that at all....  ;) The top is pretty thick though, so I doubt there'd be a crack throughout the whole thing.... I'm starting to think it's either the pump seal, or a stop fitting
https://linustechtips.com/topic/146564-leak-location/#findComment-1963535
yep most likely a broken seal, or a cracked fitting ?
https://linustechtips.com/topic/146564-leak-location/#findComment-1963536
