so my 7870 wont power up sometimes it will power up with some of the fans spinning for abit then just stop. Also i switched my motherboard from a 990fxa to a 970fx cause of broken pins, so is it the motherboard or is it the graphics card or power supply. Note: my power supply powers up all the fans i have in my phantom 410 and my liquid cooler ( h100i) just not my 7870 and my system is missing a case speaker so cant POST it
https://linustechtips.com/topic/146463-7870-wont-power-up/
How many watts is your power supply?
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/146463-7870-wont-power-up/#findComment-1955922
have you tried reseating the cables? have you tried reseating the card? are you sure everything is up to date?
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
https://linustechtips.com/topic/146463-7870-wont-power-up/#findComment-1956033
Re-install the GPU, from scratch. 750 watt is fine. Also check you have the correct 6 or 8 pins in the GPU. Maybe uninstall it, use the CPU in built graphics to install drivers. If you can't do that maybe try RMA it. Seems like a problem not with the GPU though.
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/146463-7870-wont-power-up/#findComment-1956155
