I just got a 12700k cpu
I have a cool master aio with 2 nautica outtake fans.
Other fans:
3 front intake, 1 back outtake
My cpu while gaming is hitting high 80's and sometimes 90. With all fans on high
What should i do? I tried underclcoking voltage, but for some reason did not change temps at all which i found kinda weird. I offset up to -0.150v and not changes.
https://linustechtips.com/topic/1463313-cpu-cooling-issue/
Remove the cooler and check if it has a proper mount, re-paste if needed. You don't have to actually re-paste if the application is fresh, I usually just add a small dot in the area that looks thinner on paste and just put it back on again.
Mounting pressure could also be an issue, are you sure you tightened the bolts/nuts properly?
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15622941
Are you dropping boost clocks or just running hot? AFAIK these are meant to boost into the 80s/90s same as current Ryzen chips, so long as they're below max safe temps and you aren't dropping boost clock, should be fine.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15622947
What game are you playing that actually loads up the CPU to that level?
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15622953
Oh true, most games won't push a CPU that hard. Though not sure if these new chips will just run a single/few core(s) very fast (some monitoring software will grab whatever the highest core is running and report that as full CPU temp). So could be that, or something's fucky with either mount pressure or the AIO itself.
Mouse: EVGA X17
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15622969
I am running halo infinite. the CPU is only around 30% usage. Is the case to small for this processor and 3080 ti. or will this size work? it was fine with my I7 9700f.
Do i need new cooler. what about something like this. is my case to small? is it worth it? Below is the pc with new mobo
 Noctua NH-U14S CPU Cooler
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15623300
If you didn't overclock the 12700K it should not run that hot, unless your case is really restrictive, can't see the front, but you do have lots of fans.
Check the cooler mount...
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15623310
Have you tried reseating the cpu block?
What rpm are the pump and cooler fans running at? Are power limits at stock or raised?
https://linustechtips.com/topic/1463313-cpu-cooling-issue/#findComment-15623757
