i recently Updated my iCUE software to v 4.29.203, but every light turns into Lilac-type color after seconds of closing iCUE. the only way to revert it is to restart the system it seems.
is there any way to fix this?
edit: this also happens while having iCUE open all the time, but only after a few minutes of typing
https://linustechtips.com/topic/1463019-icue-not-working-right/
Try setting your Hardware Lighting. Separate menus, separate settings, defaults to hardware lighting when iCUE is not running. I have heard that 4.29 has issues, and I think I myself might even have reverted to a previous version. Do you also have Asus Aura on GPU or board? That was an issue on my setup. I just checked and I'm using 4.28.174.
Edited by An0maly_76
Revised, more info
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1463019-icue-not-working-right/#findComment-15620502
i personally don't have Asus Aura, but i will try setting up Hardware Lighting
https://linustechtips.com/topic/1463019-icue-not-working-right/#findComment-15620662
