System wont boot with NVMe drive installed
Solved by DrMacintosh,
1 hour ago, DrMacintosh said:My motherboard is the ASRock B450M Pro4 running BIOS version 3.50, which is the latest recommended for my R5 2600. Should I upgrade my BIOS anyway?
Turns out, following my own suggestion solved my problem! Even though ASRock says they don’t recommend updating your BIOS for Pinnacle Ridge CPUs, the R5 2600 is still supported by the latest non beta BIOS (5.30)
Once I updated, I installed the drive and Windows booted! Now I should be able to clone my boot drive.
