Help with my landlady's not so good wifi
SamRed
Hi,
So my landlady has a standard Sasktel router which doesn't have very good range, she had previously bought a D-Link DAP-1820 wifi booster at the request of a previous tenant, which I find actually helps with my apartment's wifi, but I do still find that the WIFI is a bit sluggish at times and sometimes my phone will indicate no internet even though the router indicates that there is an internet connection.
Would it be beneficial if I bought a pair of TP-Link AV1000 powerline ethernet adapters to provide a pseudo hardwire connection between the router and wifi booster?
Also, her current internet connection is DSL but at somepoint soon she is going to book an appointment to get upgraded to fiberoptic internet.  Would that make any difference with the reliability of the wifi and so I should wait and see before buying EoP adapters?
Thanks
Getting Fiber Installed will likely come with a new router. Wait and see how things go after that.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
When she upgrades to fibre, SaskTel will replace your current modem/router.
The ones that come with the service are decent enough for a small-medium apartment.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
I've experimented with a couple powerline adapter setups including that same TP-Link set. If you're lucky and you can run them on the same circuit (like, the same breaker), you can pull OK speeds (~100mbps), but if not, you will be lucky to pull anything better than 15mbps down. However, even though it's slow, the connection is reliable enough for basic use and conference calling, Teams, etc. Gaming's didn't work out very well for me.
One thing I did not get to experiment with was MoCA adapters, which use the coax lines in the wall (due to the ISP at the place I was playing with already using MoCA for the cable boxes). If there's coax not being used, that might be worth trying.
