It is pretty cpu intensive. I have an i5 at 2.5 and I struggle to run it well.
Well, it requires a 2 ghz or higher clocked CPU, yes, but I'm guessing that's just the bare minimum. Since it's simulating flight, I would assume that it takes a respectable amount of CPU resources to run most of the time.
"M. Aronnax." replied the Canadian, "your arguments are rotten at the foundation. You speak in the future, 'We shall be there! we shall be here!' I speak in the present, 'We are here, and we must profit by it.'"
fx 6300?
fx 6300?
If you're asking about if it would be able to run it, then I would say that it could, but maybe not at optimal average FPS. I searched for some flight simulator benchmarks with it, but I couldn't find anything specific enough.
