My tenda router keeps disconnecting from the network, I use the Ethernet port from my university campus dorm and it s working fine without any problems but when I am using the same port with mu router it keeps disconnecting stay s up some minutes then it goes down a couple seconds or even minutes. The connections is using PPPOE as the way access the network. Had anyone encounter this problem before it s a problem from the network or the router?
Router: Tenda F9
https://linustechtips.com/topic/1460004-tenda-router-connection-problem/
Does your university allow you to use your own routers on their network?
Could be DHCP renewing the LAN IP. Most university IT departments discourage use of unauthorized student routers/APs on their network. If they notice unusual activity, they will flag your device as rogue and may take measures to terminate the connection.
