Hi everyone, I'm looking to build my first PC with the Lian Li Q58 case. I've put together a list but am not too knowledgable so would like some help with optimisations. Budget is around £1200 in the UK, and the main use case will be streaming LoL and Valorant. Please let me know your suggestions!
https://uk.pcpartpicker.com/list/gy4N9r
https://linustechtips.com/topic/1459286-help-with-mini-itx-build/
1 minute ago, Ottoman420 said:
Looks sweet. If you wait for the 13th gen to be released next month that cpu will be cheaper maybe even motherboard as well
My question is, if the poster wants to play LoL and Valorant, isn't water cooling for CPU overkill?
Unless... they want to use the CPU for the capture if it's good enough.
current PC:
PC configs I used before:
3 minutes ago, Ottoman420 said:
Sorry i should have said i dont play either of those games but from a compatabilty and size perspective it checks out.
I wouldn't put an AIO on that CPU except in this case.
You're not going to beat cooling with that AIO with any air cooler that is less than 67mm high.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Swapping to nr200 and air-cooling would allow a few upgrades.
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  (£263.99 @ Technextday)
CPU Cooler: ID-COOLING SE-224-XT Basic 76.16 CFM CPU Cooler  (£29.99 @ Amazon UK)
Motherboard: ASRock B660M-ITX/ac Mini ITX LGA1700 Motherboard  (£150.43 @ NeoComputers)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£55.99 @ Corsair UK)
Storage: Western Digital Blue SN570 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  (£73.48 @ Amazon UK)
Video Card: Asus DUAL MINI OC V2 GeForce RTX 3060 Ti LHR 8 GB Video Card  (£409.85 @ Overclockers.co.uk)
Case: Cooler Master MasterBox NR200 Mini ITX Desktop Case  (£69.63 @ Amazon UK)
Power Supply: Corsair SF750 750 W 80+ Platinum Certified Fully Modular SFX Power Supply  (£139.99 @ AWD-IT)
Case Fan: ARCTIC P12 Slim PWM PST 41.1 CFM 120 mm Fan  (£7.49 @ Amazon UK)
Total: £1208.33
Generated by PCPartPicker 2022-10-05 19:01 BST+0100
