System only being able to boot in single channel mode.
On 10/4/2022 at 4:11 PM, fuzz0r said:You're using the wrong version as far as I can tell.
You're going to need to update to 2.70 first, then continue one BIOS update at a time until you hit 3.60.
But first things first.
Download version 2.70 and try that.
On 10/5/2022 at 1:21 PM, Beerzerker said:Anything to update for your results since?
Alot of the time you don't have to go through each and every BIOS file by release version but in this case it looks that way as indicated above.
Also be sure the USB drive is placed in the correct port too if the board's flashing procedure specifies a given port to flash it from.
So I tried loading up the 2.70 update and its still not reading. I'm think at this point I think out of my own neglence or bad luck I somehow ducked my MOBO. Got a new msi B550 Board and everything working fine with my parts and new Ryzen 7 5800x.
Thanks you guys for helping me out and troubleshooting this issue I really appreciate it !
