Help I cant Decide. 4k144hz or 12700k Must decide by 9/30
Solved by ovab_cool,
11 hours ago, OldManGaming said:Ty for your suggestion, so you think(i am hoping it will) my cpu will hold up until 2025?
That depends on what you're doing with it ofcourse, if you keep playing similar games you'll be fine but if you suddenly want to play a new game that might come out it might not, though generally AAA games are more GPU heavy so i think it'll do fine till 2025
