If you have a ASUS Maximus V Formula, will there be much difference if you buy a Creative Sound Blaster Recon3D?
'Cuz the Maximus V already has the built-in audio serperately, or does that have nothing to do with it?
CPU: Intel Core i7 4790K @ 4.4GHz (cooled by Corsair H110) Motherboard: ASUS Maximus VI Formula RAM: 16GB DDR3 1600MHz CL9 | GPU: ASUS GTX780TI-DC2OC-3GD5 Case: NZXT Phantom 630 Storage: Samsung 840 Pro 128GB + 3 x WD Black 500GB  + WD Black 1TB + WD Black 2TB + Kingston V300 120GB PSU: SeaSonic Platinum 660W Monitors: 3 x Iiyama ProLite XU2390HS-1 Keyboard: Logitech G910 Orion Spark Mouse: Logitech G502 Protheus Spectrum Mousemat: Steelseries QcK Heavy (40x45) Headset: Kingston HyperX Cloud II Speakers: Logitech Z906
https://linustechtips.com/topic/14566-audio-card-needed/
I have a rampage 4 extreme and i didn't think that a sound card would make a big difference but i bought a essence stx and it was amazing. Everything sounds so crisp and i will probably never go back to not use a soundcard. I would definitley buy a soundcard if i were you! :)
NZXT Phantom, Asus Rampage IV Extreme, EVGA GTX 690, I7 3930K, 32 Gb RAM, Asus Xonar Essense STX, Samsung 830 240Gb, Seagate Barracuda 2Tb, RAT9, G19
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-161915
The Maximus has way better onboard sound than the extreme. I also have a Xonar STX and would never ever go back to having no soundcard, but it'S up to you how important sound is for you
I like speakers more than headphones, I am now using my Logitech Z906, but I don't know if there will be much difference between the very good built-in audio from SupremeFX IV or with a soundcard like the Recon3D...
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-161940
The Extreme doesn't have the SupremeFX audio unfortunately, but I think I'll buy a soundcard too  ;)
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-161971
My build for this summer, EVGA X79 Dark, 16 gigs Corsair Platinum 1866mhz, EVGA SC TITAN,  2 Samsung 840 Pro raid 0, western digital 1tbhdd velociraptor, 1200 wt psu to be continued :)
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-162253
not worth it for logitech speakers imo.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-162711
+1 not with the logitechs
What do you mean?  :wacko:
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-163843
he means, buy higher end speakers before buying a sound card.
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-163879
Ok, what do you suggest?
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-163885
I'd say swan m200mkII or mkIII, or swan m50 if you need a sub.
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-163979
I can vouch for the Swan M200MKIII, they're boss speakers
CPU: Intel i7-3770k (@4.4Ghz) Mobo: Asus Maximus V Gene Z77 RAM: 16GB DDR3 Corsair Vengence SSD:120GB Samsung EVO & 128GB Crucial M4 (Fast Storage) Storage: Hitach 3TB HDD GPU: Powercolor R9 290 PCS+ CPU Block: EK Supremacy Gold Clean CSQ Radiatiors: Alphacool NexXxoS Full Copper XT45 120mm, ST30 280mm & XT45 280mm w/ 140mm Phanteks PWM PSU: Corsair HX-650w Gold Soundcard: Asus Xense Case: Corsair Carbide A540 (Black & Gold) Front Panel: NZXT Hue & BitFenix Hydra Pro Speakers: Swan M200MKIII HeadsetSennheiser PC350 (Xense Edition)
https://linustechtips.com/topic/14566-audio-card-needed/#findComment-164480
