Can I daisy chain any RGB fans together?
1 hour ago, AliOrange said:Hi,
So I have 2 MSI ARGB fans that came with a now broken MSI MAG Coreliquid AIO. They both use a 5v 3pin connector and until now I have had them daisy chained and connected into the JRainbow socket on the MOBO. I want to add more ARGB fans to my case but do not need to have much control over the colour patterns. Can I just buy any ARGB fans from different brands and daisy chain these in? How do I know which fans have which connectors/can be daisy chained?
Also, is there an easy way to avoid using a controller as I would rather save money and just daisy chain things.
Thanks
the JRainbow socket on the MOBO is the controller if you got say an usb controller that would add more controllable connectors kinda like have more connectors on the mb
ya you can daisy chain as long as the connectors work with each other and you dont go over your mb argb voltage rating. if then connectors are different you need to find adapters or make your own / cut them of and re wire different connectors on it.
