1. Budget & Location
I'm located in Canada but I can buy parts in the US if they're cheaper.
Budget:
$3000 CAD or $2700 US
2. Aim
My new job requires a fair bit of work in Adobe Premiere, After Effects, etc.
I'm not much of a gamer and the really aim is for a work station.
3. Monitors
I already have 2 x 4K Samsung U28D590D Monitors which I intend to use.
4. Peripherals
No need for any peripherals..
I'll be running Windows 8.1. I've considered setting up a dual boot system running Mac OS.
5. Why are you upgrading?
I don't even have a desktop at the moment
What I'm thinking listed below
TOTAL: $2542.21
All help and advice are greatly appreciated
https://linustechtips.com/topic/145635-first-build/
If you are not interested in gaming I would consider swapping the 780 for a Quadro K4000, 10 bit color, and better drivers for workstation use.
Welcome to the forum BTW!
https://linustechtips.com/topic/145635-first-build/#findComment-1944433
A quadro cant run multiple monitors plus he will get cuda from the 780 give me a second to make something
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944449
A tiny bit over.
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($31.79 @ DirectCanada)
Motherboard:  Asus Z9PE-D8 WS SSI EEB Dual-CPU LGA2011 Motherboard  ($639.75 @ Vuugo)
Memory:  Corsair Vengeance 32GB (8 x 4GB) DDR3-1600 Memory  ($362.27 @ Newegg Canada)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Canada Computers)
Video Card:  MSI GeForce GTX 780 3GB Video Card (2-Way SLI)  ($529.99 @ Memory Express)
Case:  Rosewill ARMOR-EVO ATX Full Tower Case  ($119.98 @ Newegg Canada)
Power Supply:  Fractal Design Integra R2 750W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Memory Express)
Other: Intel Xeon E5-2609 V2 2.5Ghz Quad-Core Processor TIMES TWO ($751.00)
Total: $3136.54
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-28 18:06 EDT-0400)
Diamond 5 in League :)
https://linustechtips.com/topic/145635-first-build/#findComment-1944483
And id recommend adding a quadro 4000 later
http://pcpartpicker.com/p/3AgWI
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944506
@AlexanderFuentes
PCPartPicker part list: http://ca.pcpartpicker.com/p/3AgWl
Price breakdown by merchant: http://ca.pcpartpicker.com/p/3AgWl/by_merchant/
Benchmarks: http://ca.pcpartpicker.com/p/3AgWl/benchmarks/
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor  ($368.50 @ Vuugo)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($119.99 @ Memory Express)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard  ($150.04 @ DirectCanada)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory  ($169.98 @ Newegg Canada)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Disk  ($172.07 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ NCIX)
Video Card: XFX Radeon R9 295X2 8GB Core Edition Video Card  ($1699.99 @ NCIX)
Case: Corsair 300R ATX Mid Tower Case  ($69.99 @ Canada Computers)
Power Supply: Corsair Professional 850W 80+ Gold Certified Semi-Modular ATX Power Supply  ($131.25 @ DirectCanada)
Total: $3111.78
(Generated by PCPartPicker 2014-04-28 18:10 EDT-0400)
I went with this monster video card because you are using 2x Ultra 4k monitors.  The 8GB of VRAM should come in handy.  Regardless of what you end up doing, I think Crossfire or SLI is going to be required for two ultra 4k monitors.  I have also heard, AMD cards are better at task-oriented programs like the ones you intend to use.
Case is such a personal and aesthetic choice.  I went with a less expensive, but very popular and feature-rich case that is suitable for your needs.  I went really overboard with the video card, so I had to find ways to cut costs elsewhere.
I added in a 1TB HDD, wasn't sure if you would actually need it or not.
If you are going to create a "Hackintosh"  here is a handy guide for compatible components.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/145635-first-build/#findComment-1944511
Are you an idiot?
The quadro dosent have the available vram to run them it can but it will struggle
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944519
I went with this monster video card because you are using 2x Ultra 4k monitors.  The 8GB of VRAM should come in handy.  Regardless of what you end up doing, I think Crossfire or SLI is going to be required.  I have also heard, AMD cards are better at task-oriented programs like the ones you intend to use.
Really think its necessary that's half my budget. Not trying to pretend that I know anything about this...
https://linustechtips.com/topic/145635-first-build/#findComment-1944543
This is my afterburner right now
Not even 1/4th of a GB of vRAM being used. I have TWO monitors.
I budget build well. Want to learn? PM me if you want advice.
https://linustechtips.com/topic/145635-first-build/#findComment-1944544
It is not necessary, the alternative is buying 2x R9 290X and running them in crossfire.  I selected the 295X2 because it is easily the most powerful single GPU on the market, you have this monstrous budget, you deal in graphics, and it is water cooled out of the box for excellent temperatures, something that the 290Xs tend to have issues with.  Here is an alternative that doesn't cost quite as much:
PCPartPicker part list: http://ca.pcpartpicker.com/p/3AhkE
Price breakdown by merchant: http://ca.pcpartpicker.com/p/3AhkE/by_merchant/
Benchmarks: http://ca.pcpartpicker.com/p/3AhkE/benchmarks/
Video Card: PowerColor Radeon R9 290X 4GB PCS+ Video Card (2-Way CrossFire)  ($579.99 @ NCIX)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($189.99 @ Memory Express)
Total: $2630.51
(Generated by PCPartPicker 2014-04-28 18:19 EDT-0400)
I do gaming builds for the most part, so I am not in my element per say.  I just know that Ultra 4k is going to demand a very powerful GPU.
https://linustechtips.com/topic/145635-first-build/#findComment-1944594
Total: $2630.51
Thanks I'll look into both options
https://linustechtips.com/topic/145635-first-build/#findComment-1944624
Check out what other people are using for the programs and resolutions that you run.
https://linustechtips.com/topic/145635-first-build/#findComment-1944646
He has TWO 4k monitors
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944665
2,606,720 pixels. 2x 4k is about 16m pixels. Do math, thats about .00008 MB per pixel. Do more math, you would use about 1280MB which is just over 1GB of vRAM.
https://linustechtips.com/topic/145635-first-build/#findComment-1944739
sadly dosent work out like that why does stuff like the titans with 6gb ram exist then? also quote within a quote o_0
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944810
Umm... I run two monitors on my quadro at work all day every day...
https://linustechtips.com/topic/145635-first-build/#findComment-1944836
but at what resolution?
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944892
I promise not to call you an Idiot lol.
I run my K2000 with dual 1920x1080 monitors, which I openly admit is a different horse all together.
However I see you claimed that a K4000 does not have the necessary VRAM to run two 4K monitors, then turned around and recommended a 780. Both these cards have the same size VRAM, 3GB.
I stand by my recommendation of the K4000 as you also get CUDA, an infinite run time, double precision, as well as a boatload of validated programs which I suspect Adobe is one of.
Normally I am a large proponent of consumer level cards, but to me this is certainly a perfect fitment for a Professional level device such as a Quadro.
https://linustechtips.com/topic/145635-first-build/#findComment-1944961
alright you have me wrong but i still stand by a quadro not being recommended for two 4k monitors. also as far as cuda a 780 would boost his cuda and work together with the quadros
Specs
https://linustechtips.com/topic/145635-first-build/#findComment-1944982
10 Bit color?
You are correct the sheer volume of CUDA cores on the 780 will make it perform better in a purely CUDA accelerated application. I simply contend that the Quadro K4000 offers several advantages that make a real difference in a workstation machine.
Quadro's are all rated to run at %100 load 24 hours a day, indefinitely. This is not something that everyone will utilize but what it does display is the level of quality control and design attention that is paid to the professional cards is substantially higher than that paid to the consumer cards.
Now if you are suggesting to run a Quadro in conjunction with a 780 for higher levels of CUDA performance, I would agree. I just don't see that happening at within the budget. :)
https://linustechtips.com/topic/145635-first-build/#findComment-1945014
