My cpu of my laptop is overheating as hell.....
I repasted it with brand new thermalpaste.
There is no dust inside.
The fan is blowing at almost at maximum because of the temperature.
Its random shooting too 100c while its doing nothing.
The power doesn't increase and the cpu usage doesn't increase.
Already reinstalled all the drivers ect.
I'm out of idea's
Laptop specifications:
AMD Ryzen 7 PRO 4750U
256GB SSD
16GB RAM
This the the exact model click here
Here a screenshot of HWiNFO64:
Custom Build, i9 10900K 5,3Ghz All Core, Asus ROG STRIX Z490-A, Asus RTX ROG STRIX 3090 OC, 4x 32GB 3600Mhz DDR4, Samsung Evo Pus 970 500gb, Samsung Evo Pus 970 1TB, 4TB HDD 5,400 RPM, Corsair AX1600i 1600 Watt, CUSTOM WATERCOOLING LOOP, Corsair Obsidian 1000D
https://linustechtips.com/topic/1455414-laptop-cpu-overheating-problem/
I don't see 100C in your screenshot. What I do see is CPU package power peaking at 27W which can easily push temps to the high 80s on a thin and light. This all looks normal.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
the thinner the laptop, the less heatsink it has.
The less heatsink, the hotter the chip will run.   No two ways about that.
It's a known issue that super thin laptops (and the majority of laptops today) run very very warm.
TBF these temps looks fairly normal, especially for the specs you listed. You have a powerful cpu, and packing that into a small chassis presents some thermal challenges. My older gaming laptop had similar issues, especially since the wattage of the cpu was quite high. You can always reduce the wattage with something like ThrottleStop if its that much of an issue, but I wouldn't worry about it too much.
