So I recently just bought my pc parts I will send the list below.
https://ca.pcpartpicker.com/list/B2RNBj
I know it's not the best price efficient or performence, but it's what my friend gave me.
Okay, so onto the pc; i followed many tutorials on what cables go where, what to plug into, etc, but my pc still doesnt boot. I have turn on the psu switch, and plugged in the coord.
Although, the tutorials i were folling where somewhat out dated.
In my case I have coords which were not included in the tutorial.
if you need anymore information lmk, or any pictures of cables, and if you could let me know where to plug in everything such as audio, +power, - power, etc. As Im not as confident in that tutorial anymore...
Please lmk if you need more info.
https://linustechtips.com/topic/1454644-just-help/
Pcpartpicker list is empty. Copy+paste the correct link.
It would be listed here.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1454644-just-help/#findComment-15560845
4 minutes ago, lapdity said:
my bad its been edited.
Thanks.
Check to make sure your RAM sticks are in slots 2 and 4?? Try checking with one at a time, starting with slot 2.
https://linustechtips.com/topic/1454644-just-help/#findComment-15560881
BUILD GUIDE
Thermal Paste (X Method)
What Comes After
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1454644-just-help/#findComment-15560888
24 minutes ago, Pixelfie said:
Probably an outdated BIOS. You'll need an older CPU to update it, possibly all the way back to Ryzen 2000.
Does the motherboard have a sticker saying what BIOS version? Or maybe it says it on the box?
on the motherboard boxs it says amd ryzen 5000 desktop ready
https://linustechtips.com/topic/1454644-just-help/#findComment-15560913
The 5500 was released later than the other Ryzen 5000 CPUs. 5500 requires BIOS version F63, and most other 5000 series require F61. If you can find what version is installed that could help.
https://linustechtips.com/topic/1454644-just-help/#findComment-15560922
where do you think i could find that out, maybe the user guide?
https://linustechtips.com/topic/1454644-just-help/#findComment-15560925
47 minutes ago, lapdity said:
also where would i plug this in, i think its a fan coord, but i have no idea where to put it. (i have 3 of these coords)
Simply check where it came out from, if it's from a fan, it's a fan cable. a 3 pin (Non PWM, PWM version is 4 pin) one.
If it's PC case fan cable, it plugs to fan header on your motherboard that aren't labeled CPU_FAN, If it's CPU cooler fan cable, it plugs to CPU_FAN header.
Refer to your motherboard manual for where the locations of the fan headers. (Page 3 and 4 of the manual is a good place to start)
The headers most likely will be 4 pin, it can accept 3 pin female one, they are keyed, so align the keying then slide them in.
For most connectors, the information is in the manual for the motherboard / AIO / pc case / PSU
https://youtu.be/BL4DCEp7blY
Refresh before you reply
https://linustechtips.com/topic/1454644-just-help/#findComment-15560963
would it be named sys fan? if so i only have 1.
https://linustechtips.com/topic/1454644-just-help/#findComment-15560982
Seems so, you will have to use either a splitter cable or a fan hub if you want to connect more than 1 case fan.
Or use a 3pin to molex/sata adapter and power the rest of the fan through Molex/Sata (meaning you can't control their speed, they will run at 100% all the time)
IIRC, 1 fan header can handle around 1 amp, so enough for 3 fans.
What is the brand and model number of the fans ?
https://linustechtips.com/topic/1454644-just-help/#findComment-15561173
they're the stock fans in my case which you can check in my pc case.
https://linustechtips.com/topic/1454644-just-help/#findComment-15561353
Damn, that case doesn't come with PWM fans i guess.
Oh well, yeah, you need splitter / fan hub. And possibly 3pin extension cable too if the inbuilt cable length is still not enough even after adding splitter length.
A 3 way splitter.
Additional fans after 3 gonna have to use 3pin to molex/sata adapter & run at 100% all the time i guess.
Technically 1 header can handle current pull from 4 fans (1 standard fan is around 0.25amp), but I personally prefer to leave a bit of a headroom instead of putting the header to it's max limit. But, you do you
You'll be controlling the fan curve through DC mode in BIOS.
https://linustechtips.com/topic/1454644-just-help/#findComment-15561672
