Hi guys,
So, I'm just wondering, what is the recommended minimum amount of case that you can put in a case and still have a sufficient amount of airflow?
Thanks in advance for your help guys. :D
EDIT: To help you out I will include my finalised build configuration.
PCPartPicker part list: http://au.pcpartpicker.com/p/3zWbl
Price breakdown by merchant: http://au.pcpartpicker.com/p/3zWbl/by_merchant/
Benchmarks: http://au.pcpartpicker.com/p/3zWbl/benchmarks/
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($389.00 @ PCCaseGear)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler ($59.00)
Motherboard: Gigabyte GA-Z87X-D3H ATX LGA1150 Motherboard ($189.00 @ PCCaseGear)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory ($115.00 @ PCCaseGear)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($109.00 @ PCCaseGear)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($175.00 @ PCCaseGear)
Video Card: EVGA GeForce GTX 770 2GB Video Card ($429.00 @ PCCaseGear)
Case: Nanoxia NXDS1W ATX Mid Tower Case ($119.00)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($133.00)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($115.00)
Case Fan: Arctic Cooling Arctic F12 Pro PWM 57.0 CFM 120mm Fan ($12.00)
Case Fan: Arctic Cooling Arctic F14 PWM 77.3 CFM 140mm Fan ($15.00)
Other: EVGA GTX 770 Backplate ($29.00)
Total: $1900.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-28 17:39 EST+1000)
Edited by Geekazoid
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/145361-case-fans/
depends on how much components you stuff in the case.
Are you running SLI graphic cards in a mATX case?
Hi guys,
Use the quote or multiquote, for faster responses \/ \/
https://linustechtips.com/topic/145361-case-fans/#findComment-1940965
Two, maybe one, but with two you could have one intake and one exhaust.
So 3 should be ample, yes? Even if you're going to possibly overclock the CPU down the road?
https://linustechtips.com/topic/145361-case-fans/#findComment-1940967
I usually do twice as many intakes as outputs. So if you have 0 outputs, 1 intake. Filtered of course. The sheer amount depends on the layout of the case.
The ideal size is 120-140mm as fans larger than that hit diminishing returns from the increased size - especially in static pressure - due to blade wobble. The big advantage to larger fans is less perceived noise as they are a lower frequency hum rather than a mid-high pitch whine
In case the moderators do not ban me as requested, this is a notice that I have left and am not coming back.
https://linustechtips.com/topic/145361-case-fans/#findComment-1940970
Yep, maybe two intake and one exhaust. I think 4 would be the perfect amount. You could go without case fans, your CPU and GPU cooler should be good enough, but obviously having some doesn't hurt lol
https://linustechtips.com/topic/145361-case-fans/#findComment-1940973
Depends on the components and scenario.
There are systems that use no fans and rely on passive cooling and there are systems decked out with them.
https://linustechtips.com/topic/145361-case-fans/#findComment-1940976
I've included my build above so that you guys can get a better idea of how many case fans that you believe I would need. The build is 80% for video editing with the occasional 20% for gaming (usually just racing games, mostly Need For Speed World).
https://linustechtips.com/topic/145361-case-fans/#findComment-1941000
You could just have 2 intakes I guess, because you can always have your CPU cooler exhausting out the back of the case as well.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/145361-case-fans/#findComment-1942472
