4 hours ago, bmx6454 said:
what graphics settings are using in game(max/med/low/mix)? are you on battery, or plugged in? use msi afterburner or something similar with overlays to see if it's using the 3050, or igpu.
Tryed any settings. Its stable 50% utilization and max 30 fps in game and 50 in menu. Was using afterburner on plugged in. Applied high performance settings in NVIDIA control panel and still nothing.
https://linustechtips.com/topic/1453491-low-fps-in-games/#findComment-15553053
