Well i wasn't sure where to put it but meh mods are welcome to move it.
So i´m looking for a Air compressor Within Europe.
Thing is i want a SMALL one.
This is the one im looking at right now
http://www.redcoon.nl/B421478-STANLEY-Compressor-DN-200-8-6_Compressoren
Why don´t i buy it? Two reasons: Loud and out of stock till June.
So i´ll use the above one as a reference or whatever its called.
So anyone knows of an Air compressor that's similar to the above ?
NOTE: im aware i cant get silent one but im only asking for something not as loud as 90+ db
Specs:
8 bar min/max
Oil free
4-10L tank
quiet
Small
In stock
Price around 100-200 Euro/GBP
https://linustechtips.com/topic/145129-air-compressors/
should go in off topic, but. Here in the US, we have 2 craftsmen air compressors. one is a smaller one we can carry around the house, the other is a much larger one we leave in the garage. If you can get a craftsmen i would highly recommend it
looks interesting, ill take a look and se how they fare, and if they are avaible in europe or can be shiped outside US.
https://linustechtips.com/topic/145129-air-compressors/#findComment-1938129
What are you going to be using it for?
Here's a silent one from a swedish toolshop
http://www.swedol.se/bygg-anlaggning/tryckluft/kompressorer/tl-14405.html
https://linustechtips.com/topic/145129-air-compressors/#findComment-1938565
ha! I was mostly looking at clas ohlsson, jula or biltema when i was looking for one, that and google but it kept showing me sweclockers results and the suggestions from there mostly aimed at Jula.
Thanks ill check it out as well.
Usage: mostly cleaning the pc's, painting stuff and pumping up tiers. Oh and im tired of cans and hand pumps....
https://linustechtips.com/topic/145129-air-compressors/#findComment-1938866
