Building my first file server, need help
Solved by LIGISTX,
23 minutes ago, LemonJuice147 said:Windows for OS and usage will currently just be for file storage to use instead of onedrive, and would Synology Hybrid Raid work better with different sizes and types?
And probably will buy some HDD's
Unraid is likely what you want if you plan on using different sized drives. It’s not actually RAID, which is why it works well for that. And it is easy to add storage later.
