Not sure there's something to save on an old used case for $25 with $25+ shipping vs a new budget one that will cost $50 🙂
https://linustechtips.com/topic/1449426-case-advice/#findComment-15524314
I understand that shipping is the main problem with cases but here in East Europe at least locally shipping costs around 8$. The main purpose of the matx case is that I'll be traveling around the country and I don't want a drag fulltower with me. Are there any old designs that are in matx form or just a small old case will do?
https://linustechtips.com/topic/1449426-case-advice/#findComment-15524358
18 hours ago, Dethanu said:
I'm looking for a MicroATX case that I can put a new system but I really don't want to spend a lot of money on it. Any old matx case suggestions that I can shop around used?
What is your budget?
https://linustechtips.com/topic/1449426-case-advice/#findComment-15525203
3 minutes ago, Dethanu said:
Around 50-60 bucks
https://de.pcpartpicker.com/products/case/#t=5,7,6,8&X=0,6061  Heres a PCPartPicker filtered list shopping in Germany (there's a few euro countries on the site but Germany seems to typically have the best case selection)
You can sort further by PSU size, CPU tower height / RAD size, and number of drives. In order to filer by Max GPU length you'd need to add the GPU to your "build".
You haven't mentioned what parts you're using so I cant offer any more specific cases yet.
https://linustechtips.com/topic/1449426-case-advice/#findComment-15525335
I'll be using it for a i3-12100F with a GTX 1050ti and a seasonic SII
https://linustechtips.com/topic/1449426-case-advice/#findComment-15525350
Ah, then I'd say you have no physical restriction you'd need to adhere to. The MATREXX 30 or 40, Tecware Forge M, KOLINK Citadel Mesh, Silverstone FARA H1M, or anything similar would do just fine.
https://linustechtips.com/topic/1449426-case-advice/#findComment-15525394
