Transporting a Curved Monitor
1 hour ago, Ehrix said:So I’m moving off to college and I have to drive about three hours. I have a curved monitor that I want to bring but I don’t know how I should go about it. I’ve thought of just placing it on top of a pillow but idk how good that will be.
Never dealt with curved before, but I'd do it by laying the monitor on the seat, with the screen facing up & base facing forward.
If the square (or whatever shape) base is detachable I'll detach it, I only need the "pole"
Then I'll tuck the seatbelt ribbon (the waist part) between the monitor & base, then zip-tie the starting end of the ribbon so that it won't slacken. This way it should atleast prevent the monitor from sliding/launching forward. Seatbelt only automatically stops slacking if it's pulled fast & hard enough, hence the zip tying.
I probably also gonna put something soft under the left and right "wing"
But of course if you still have the box it came with, do as @Andrewtst said.
