Need some help finding the perfect phone.
Solved by Pixelfie,
The Sony Xperia 1 IV seems like the perfect choice for you. It has a Snapdragon 8 gen 1 (one of the best chipsets currently available apart from 8+ gen 1 which isn't a huge upgrade), no notches or holes or anything like that, 120hz 1644x3840 OLED screen, good cameras, fingerprint scanner in power button, USB 3.2 and a headphone jack. Also has front facing speakers which sound good. Pretty much exactly what you asked for. Keep in mind that it doesn't come with a USB cable, so you might have to buy one if you don't have a USB-C cable yet.
