Oof, youre 100w off from the recommended psu capacity. An RTX 3070's recommended psu is 650w.
With the transient spikes of RTX 30 series, there's no chance you'd be able to run it off of a 650w psu.
Some of Linus's intel extreme upgrade series wuth 3080s  tried the 650w psu, James was one of them. He ended buying 850w psus.
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1449216-power-supply/#findComment-15522764
Your system will use at max around 600W, so 650W is enough "technically"
However, you need a good PSU because such a load may either make it hot/noisy, or worse it may trip on GPU "power surges" that can make the GPU reach 500W+
To be on the safe side I'd suggest you get a good 850W PSU (say Corsair RMx, around $130)
https://linustechtips.com/topic/1449216-power-supply/#findComment-15522770
5 minutes ago, DanskieTV said:
im not sure it was a pre built i bought in 2020 and when i checked the specs it just says corsair 650w psu
The PSU sticker should have the name right... Like VS650 RM650 CS650 or something.
Regardless, you need to upgrade your PSU, otherwise there would be shutdowns when youre putting the PC under load.
https://linustechtips.com/topic/1449216-power-supply/#findComment-15522780
Real talk that PSU would likely be perfectly fine.  There's no point in "pre upgrading".  Just try it and if it clicks off at some point you need more.
Workstation:  9800X3D|| Asus X670E ProArt Creator || MSI Gaming Trio 4090 Shunt || T.Force 7800CL34 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 13700K @ Stock || MSI Z690 DDR4 || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ P-Core only || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 4070 RTX Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
https://linustechtips.com/topic/1449216-power-supply/#findComment-15522812
2 minutes ago, DanskieTV said:
i just took apart my pc and its a RMX 650w ( when i say took apart my pc i mean i took off my gpu shroud and pulled out my psu )
Did they gave you all the cables with the PSU when you bought the system? 2 PCI-e cables with two 6+2 pin connectors each and a bunch of PATA and SATA cables?
https://linustechtips.com/topic/1449216-power-supply/#findComment-15522835
This is a quality unit, don't replace it right away. If your 3080 ti runs stable without crashing, you can definitely stick with the RMX. The only real issue with the 30 series is the transient power draw, spikes that cause instability. If the unit can handle the spikes without issues, then no prob.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1449216-power-supply/#findComment-15522865
Wow!  Surprised a pre-build has such a quality unit.
Here's what you do:  You upgrade the GPU.  If the PC shuts down, you know you need to upgrade to a higher wattage PSU.  Done.
https://linustechtips.com/topic/1449216-power-supply/#findComment-15523099
