SSUPD Meshlicious Standoff Mod Help Required
16 minutes ago, Marexn said:Yeap, those look good, but the main reason I'm asking the question is that is there any reason why I haven't seen people using them before?
Like is there grounding issue or that they are more conductive or something? All I'm basically asking is that am I save going with them not to brick my PC?
Well, AFAIK the standoff supposed to short to ground if something happens.
Will using nylon spacer brick your PC? most likely not, since some people build PC in a wooden case or make a test bench using acrylic, at least not unless there's some serious issue happening entirely.
Personally I prefer metal spacer, more robust & can withstand heat more (won't deform in a hot PC environment).
Add a chonky cooler, a chonky GPU, that motherboard (and in relation the spacer) gonna have to help hold those weight.
To the point that Motherboard flex due to too chonky of a cooler occurs sometimes.
Why people not bother with black spacer? because there is no way they'd be able to see it once they put their motherboard on top of it.
Especially so with ITX build.
So they just bothered with black motherboard screw. They'll forgot about the spacer the instant their PC turn on and everything is fine.
