Isn't there some underneathe that daughter board thing?
https://linustechtips.com/topic/144881-help-only-2-standoffs/#findComment-1934803
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
https://linustechtips.com/topic/144881-help-only-2-standoffs/#findComment-1934807
What case? What do you mean?
You mean only two holes? Did you look a lot? That's not something that just isn't put into a motherboard.
Sorry. I mean it only haas 2 standooffs holes. Crosair 250d has 4 standoffs pre installed I think (right?) and they don't really align
https://linustechtips.com/topic/144881-help-only-2-standoffs/#findComment-1934811
he is talking about the holes on his mobo
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/144881-help-only-2-standoffs/#findComment-1934813
I believe you're supposed to unscrew two of the screws that hold down the heatsink on the daughter board, and use those.
https://linustechtips.com/topic/144881-help-only-2-standoffs/#findComment-1934816
awe at first I thought he was talking about that his case only had 2 standoff screws.
https://linustechtips.com/topic/144881-help-only-2-standoffs/#findComment-1934823
