Tried to install an m.2 drive, now my system isn't booting.
Solved by bmx6454,
40 minutes ago, BlindGuyPCs said:Fans all spin, RGB lights up on the GPU, but no output to the display. I tried a different GPU. No luck there.
only other things i can think to try is to re-seat ram(also try with only one stick at a time) and all of the psu connectors, and try with no sata cables connected(grasping at straws on that one). just to make sure, the pc was off and the psu switched off when you installed the drive?
