Need some help with my first pc Build.
Dodaco
Please review my list and give me some feedback. Am I missing anything?
I´m struggling to with what CPU cooler to get, because I don´t know what look for and how to tell, what is enough.
Also: Where´s the different between all the different Graphics Cards with the same Chipset? And why are the prices so different?
I´m not set on it having to be a 3090 btw, but for rendering, the bigger the better, right?
Any help would be appreciated
Budget (including currency): ~2500
Country: Germany
Games, programs or workloads that it will be used for: 3D Rendering, Game Development and Gaming
https://pcpartpicker.com/list/NhMYRv
no peripherals needed
Looking to buy ASAP
About what id recommend
https://de.pcpartpicker.com/list/tM3QKp
The 12700f will perform usually better than the 5900x while being cheaper
Chea0 aftermarket cooler to keep the cpu cool
Cheap mobo for the price
Cheapest kit of 32gb ram
2tb storage
Cheapest 3090. You probably won't see a lot of benefit of a 3090 since by the same you see 24gb of vram, it'll start to overheat, but you have the budget for it why not
Nice case and a great 1000w psu since 3090s are power hungry
Depending on what monitor you currently have, I'd reccommend switching the gpu to a 3080 and buying a better monitor if yours isn't good already
Lots of weird choice, and your list was US
The best cooler  at good price is the AK620
I'd keep the 5900X it's a good chip, but will get a 3080Ti, the 3090 is a waste of money if you don't really need the 24GB VRAM
With the savings on the GPU I've improved everything else : top notch board, 32GB RAM 3600CL16, 2TB NVme + 4TB HDD (optional...), 1000W PSU, and a great case
A bit over budget tho at 2600EUR, but you can get back in with a cheaper key or a smaller HDD
PCPartPicker Part List: https://de.pcpartpicker.com/list/pJmhv3
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  (€388.00 @ Mindfactory)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (€73.67 @ Amazon Deutschland)
Motherboard: MSI MEG B550 UNIFY-X ATX AM4 Motherboard  (€261.06 @ Amazon Deutschland)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  (€153.90 @ Alza)
Storage: Crucial P5 Plus 2 TB M.2-2280 NVME Solid State Drive  (€229.98 @ Mindfactory)
Storage: Western Digital Black 4 TB 3.5" 7200RPM Internal Hard Drive  (€203.18 @ Amazon Deutschland)
Video Card: Inno3D GeForce RTX 3080 Ti 12 GB X3 OC Video Card  (€1054.99 @ Caseking)
Case: Lian Li Lancool II Mesh C RGB ATX Mid Tower Case  (€144.51 @ Amazon Deutschland)
Power Supply: Phanteks AMP 1000 W 80+ Gold Certified Fully Modular ATX Power Supply
Operating System: Microsoft Windows 11 Home OEM 64-bit  (€107.17 @ Amazon Deutschland)
Total: €2616.46
Generated by PCPartPicker 2022-08-08 00:23 CEST+0200
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
So you´re both saying 32 GB of Memory and 1000W PSU?
I quite like the look of the NZXT H510 Flow. Would that work?
It's an okay case, it's just not really worth the price it usually goes for. If you don't like the look of the p400a, see if you like either the 4000d airflow or 500dx. Another good option is the fractal design meshify c
28 minutes ago, Dodaco said:
Thanks for your advice
I´ve come up with this combination of both your suggestions
https://de.pcpartpicker.com/list/KwRxxs
Thoughts?
3080ti for 1000+ euro is not worth it. Maximum a 900euro card. Just get a 3080 for 700-800euro.
Don't pay full price for OS. Reseller will have one for 20euro.
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
