Budget (including currency): Around 2,000 gbp (British Pound) Would be nice to be able to go lower.
Country: England
Games, programs or workloads that it will be used for: Mostly programs : Rendering , dawnloading stuff , transfering stuff.Burning Dvd's etc.
Other details : Needs to have dvd/blu-ray and also card reader .
Computer will be gift for father and his bday.
He has very old rig which is super slow so looking to upgrade pc for him. It will be used as stated above mostly rendering/editing stuff dawnloading stuff and transfering stuff.
Basically I want it fast please ! x) . No other things are needed got monitor already.
Thank You in advance Smart people !
https://linustechtips.com/topic/1448017-build-for-father/
3 hours ago, kitnoman said:
with half or little over half your budget, you could probably build a ryzen 5600/ ryzen 5700x/12th gen 12400/ 12th gen 12700 setup with a dedicated gpu(just in case some of the render/software needs gpu).
Well I would be very happy for providing parts list since I'm not an expert about computers TA
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15513921
PCPartPicker Part List
CPU: Intel Core i7-12700 2.1 GHz 12-Core Processor  (£344.44 @ Newegg UK)
CPU Cooler: Scythe Fuma 2 Rev.B 39.44 CFM CPU Cooler  (£71.00 @ SmartTeck.co.uk)
Motherboard: MSI PRO B660M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  (£141.65 @ Box Limited)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£107.99 @ Amazon UK)
Storage: Western Digital Black SN770 2 TB M.2-2280 NVME Solid State Drive  (£164.99 @ Ebuyer)
Video Card: MSI GeForce RTX 3060 Ti LHR 8 GB VENTUS 3X OC Video Card  (£463.48 @ Ebuyer)
Case: Silverstone ALTA G1M MicroATX Mid Tower Case  (£141.48 @ Scan.co.uk)
Power Supply: Corsair SF750 750 W 80+ Platinum Certified Fully Modular SFX Power Supply  (£119.99 @ AWD-IT)
Operating System: Microsoft Windows 11 Home OEM 64-bit  (£97.99 @ Box Limited)
Total: £1653.01
Generated by PCPartPicker 2022-08-07 16:34 BST+0100
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15513933
Sure thing! Since you already have an intel build above, let me give you an AMD alternative build at around the same price, which could be same or better in terms of performance. Alternatively, you can just get 5700x for cpu and at least 3060/3060ti/6600xt/6700xt and it would be around £1200-1300. You would still need a good gpu as you really did not specify every software that's that your dad is using.
Pcpartpicker
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  (£355.97 @ Overclockers.co.uk)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  (£72.26 @ Technextday)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  (£144.39 @ CCL Computers)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  (£112.99 @ Amazon UK)
Storage: Intel 660p 2 TB M.2-2280 NVME Solid State Drive  (£148.99 @ AWD-IT)
Video Card: PowerColor Radeon RX 6800 16 GB Fighter OC Video Card  (£558.89 @ Overclockers.co.uk)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (£75.48 @ Amazon UK)
Power Supply: Corsair RMx (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£133.48 @ Ebuyer)
Operating System: Microsoft Windows 10 Home Full - USB 32/64-bit  (£28.99 @ Amazon UK)
Total: £1631.44
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15514248
About what id reccommend
https://uk.pcpartpicker.com/list/ZWF9wc
The 12700f is a good cpu choice for most professional work, and About what id choose for this price
Cheap aftermarket cooler to keep the cpu cool
Good board for the price
Cheapest kit of 32gb ram.
Good 2tb storage
I'd try and go nvidia here since they're more suited to professional programs
Nice case and a good 850 watt psu
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15514299
Pcpartpicker
Total: £1631.44
This build says it has:
Warning! These parts have potential issues or incompatibilities.
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15515354
On 8/7/2022 at 11:27 AM, Modem56 said:
are you okay with giving him a second hand PC and if your close to brighton you can get this https://en-gb.facebook.com/marketplace/item/439994054710858/?ref=search&referral_code=null&referral_story_type=post
We ain't buying your PC. Maybe for £1000, no more.
Hate these ads where they only show MSRP on expensive parts to make it seem like you're getting a good deal.
Bro nice to know "wifi antenas" are a nice addition...
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15515396
The motherboard has a BIOS Flash button that allows BIOS updating without a working CPU.
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15515610
34 minutes ago, XenresEU said:
Edited info a bit after researching what father likes. Needs to have Dvd/Blu-ray and card reader ;x
If it's not a problem for your father I think there are some card readers/ DVD readers that you can connect to the PC via USB.
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15517332
https://uk.pcpartpicker.com/list/M3fWJM this here would be my build.
I chose this case because it has 2 ODD slots/ 5.25" bays which can be used for DVD readers (the DVD readers do not come with the case).
Motherboard: MSI MAG B550M Mortar WiFi Micro ATX AM4 Motherboard (£133.99 @ box.co.uk )
Memory: Corsair Vengeance LPX 32 GB (2 X 16 GB) DDR4-3600 CL16 (£135.46 @ scan.co.uk)
Storage: Western Digital Black SN850 2 TB M.2-2280 NVME Solid State Drive (£185.99 @ scan.co.uk)
Video Card: Gigabyte Radeon RX 6800 16GB Gaming OC (£579.89 @ overclockers.co.uk)
Case: Fractal Design Pop Air Mini MicroATX Mid Tower Case (£94.99 @ scan.co.uk)
Power Supply: SeaSonic Focus GX 850W 80+ Gold Certified Fully Modular ATX (£110.53 @ cclonline.com)
Total: £1698.07
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15517379
Personally I think a usb card reader is better as it can be easily replaced when format change. But there is room in the case to handle a 2nd external opening 5.25 device.
CPU: Intel Core i7-12700 2.1 GHz 12-Core Processor  (£346.99 @ Technextday)
Motherboard: MSI PRO B660M-A WIFI DDR4 Micro ATX LGA1700 Motherboard  (£142.85 @ Box Limited)
Video Card: MSI GeForce RTX 3060 Ti LHR 8 GB VENTUS 3X OC Video Card  (£459.99 @ CCL Computers)
Case: Fractal Design Pop Mini Air MicroATX Mid Tower Case  (£94.99 @ Scan.co.uk)
Optical Drive: Asus BW-16D1HT Blu-Ray/DVD/CD Writer  (£78.73 @ Amazon UK)
Custom: Pop Mini Air USB-C 10Gbps Cable – Model D (£8.99)
Total: £1694.50
Generated by PCPartPicker 2022-08-09 21:24 BST+0100
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15517404
Please do not post Facebook links to used pcs this is counterproductive to the topic. And if you wish to post such things we have a classifieds section for a reason.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15518174
57 minutes ago, XenresEU said:
Could You make a build closer to around 1.9k - 2k ? Please. Ta ^_^
CPU Cooler: Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler  (£85.55 @ Amazon UK)
Motherboard: MSI MAG B660 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard  (£191.57 @ CCL Computers)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (£99.49 @ Box Limited)
Video Card: MSI GeForce RTX 3070 LHR 8 GB SUPRIM X Video Card  (£556.00 @ Amazon UK)
Case: Fractal Design Pop Air ATX Mid Tower Case  (£98.88 @ More Computers)
Power Supply: Corsair RMx (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£109.49 @ Box Limited)
Optical Drive: Pioneer BDR-209DBK Blu-Ray/DVD/CD Writer  (£126.27 @ Amazon UK)
Custom: Pop Air USB-C 10Gbps Cable – Model D (£8.99)
Custom: PNY High Performance Flash Memory Card Reader All In One USB3.0 (£16.49)
Total: £1902.70
Generated by PCPartPicker 2022-08-10 17:52 BST+0100
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15518537
Total: £1902.70
Is this ok in build You made?
  • Note: The Noctua NH-D15 chromax.black 82.52 CFM CPU Cooler may require a separately available mounting adapter to fit the MSI MAG B660 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard.
  • Disclaimer: Some physical dimension constraints are currently not checked, such as CPU coolers and RAM clearance.
Sorry for asking so much!
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15519690
Interesting that you want to raise the price but sure. Something like this should be easy to build and last ages. Consists of only high quality, reputable brands.
CPU: Intel Core i5-12600K 3.7 GHz 10-Core Processor  (£273.51 @ Amazon UK)
Motherboard: Gigabyte Z690 AORUS ELITE AX DDR4 ATX LGA1700 Motherboard  (£225.79 @ SmartTeck.co.uk)
Memory: Kingston FURY Beast RGB 64 GB (2 x 32 GB) DDR4-3200 CL16 Memory  (£217.44 @ NeoComputers)
Storage: Samsung 980 Pro 2 TB M.2-2280 NVME Solid State Drive  (£227.70 @ Amazon UK)
Video Card: Gigabyte GeForce RTX 3070 Ti 8 GB AORUS MASTER Video Card  (£705.97 @ Amazon UK)
Case: be quiet! Pure Base 600 ATX Mid Tower Case  (£92.75 @ Technextday)
Power Supply: Corsair HX1000 Platinum 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  (£153.49 @ Amazon UK)
Optical Drive: LG GH24NSD5 DVD/CD Writer  (£16.48 @ Amazon UK)
Case Accessory: Vantec UGT-CR935 Card Reader  (£29.41 @ Amazon UK)
Total: £2014.80
Generated by PCPartPicker 2022-08-12 09:31 BST+0100
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15519721
The NH-D15 has been shipping with an LGA 1700 bracket since December 2021. The note is present to advise those with older units that a bracket may be necessary.
The memory modules are low profile and do not conflict with the cpu cooler.
The installed height of the NH-D15 is 165mm. The case CPU cooler height limit is 170mm.
The NH-D15 is compatible with the motherboard and there is no  interference with VRM heatsinks.
The GPU is 335mm long. The case GPU length limit is 405mm.
https://linustechtips.com/topic/1448017-build-for-father/#findComment-15519827
