Trying to power CableMod RGB/UV strip
Solved by thrasher_565,
5 hours ago, stellarshy said:Thank you in advance for any help – I recently purchased this CableMod widebeam hybrid RGB/UV kit without realizing that it uses some kind of nonstandard 5 pin connector for RGB/power. I'm trying to find a way to convert it to be compatible with standard four pin RGB headers. all I care about is the UV portion.
connect the vu to one of the other colors or connect it off 12v off the psu but that will be 100% all the time. could connect it off a fan header too if you have one you can control
