Hello,
My modem is connected to coax that is upstairs in my home. My router is also upstairs with the modem and that connection is the only one available for the modem. I was wondering if my connection speeds and strengths would be improved in my downstairs game room if I connected a 2nd spare router to the wifi and placed it downstairs and then hardwired my devices to the second router. Thanks!
https://linustechtips.com/topic/1447871-running-two-routers/
Not really. That second router would still have to connect to the weak WiFi connection downstairs.
The 'right' thing to do is run a network cable downstairs and add a network switch.
https://linustechtips.com/topic/1447871-running-two-routers/#findComment-15512697
If you want to use a second router as an AP your best performing option is to run a cable to it from the first router then configure the router to act as an AP.
Using a router or other similar device as a Wi-Fi repeater would result in similar or worse performance depending on repeater placement.
https://linustechtips.com/topic/1447871-running-two-routers/#findComment-15512747
