Elden Ring negative fps
Go to solution Solved by Tan3l6,
25 minutes ago, The_Hackintosh said:
If no reinstall windows.
Jebus, that seems an overreaction.... DDU before that step would be advised.
Is it a fresh install of windows? If no reinstall windows. If it is DDU the Driver(s) and reinstall, if that fails use an older driver.
Ryzen 9 5950X Gigabyte Aorus Elite B550 V2  MSI RX 6750XT Corsair HX1200 3xLL120 Fans 7xA12x25 Fans 5000D Airflow Vengeance RGB PRO 1.450 @ 4133MHz CPU Cooler: NH-U12A
18 minutes ago, Georgeskal said:
Hello,
My friend recently bought a new gaming pc:
i7 11th gen
16gb Ram
RTX3050
We tried to play to elden ring, we put all the setting to low, and he was on perma 15-20 fps, shouldn't his pc be able to handle it atleast at low no?
What's the resolution you're playing at?
Ahem... Yes indeed a DDU.. a.. yes sure.. uhh... (What's a DDU), also we r just playing at 1080p resolution
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
3 hours ago, Hairless Monkey Boy said:
Would using the elden ring game ready driver from nvidia boost performance by this much tho? because right now it's litteraly at 14fps for some reason, i can't imagine a driver downgrade could get it to 60fps but I won't be mad if I'm wrong, also i can't really reinstall windows so easily so would it really fix the issue because it's gonna take over a month to backup the stuff we need to do the reinstall
I just had a thought, could it be the cpu turbo bottlenecking the game? I read that elden ring is very cpu intensive aswell, i don't know the exact model of the i7-11th gen but could this be a thing that's happening?
Is Elden Ring the only game giving low fps?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
