I'm quite new to networked attached storage and was wondering, how does setting up any type of RAID in a NAS work? (As in how would you go about doing it?) Does the NAS work like a standard PC and have an OS?
Thanks,
Blueprint
Intel i7 4790k / MSI Z97M / Hyper 212 Evo / MSI Twin Frozr GTX 770 / 16GB Corsair Vengeance 1600MHz / Fractal Design Arc Mini R2 / Corsair CS750M / Samsung 840 Evo 250gb SSD /  WD Blue 1TB
https://linustechtips.com/topic/144620-how-does-raid-1-work-in-a-nas/
Thanks,
Blueprint
Some NAS's will have a standard OS like Windows server. Or they will have their own variant of some form of LInux. It's not tot hard to set up. Looking in the manual will show you how. I could tell you but it's different per every NAS.
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
pre-configured NAS devices have some kind of DOM which the system is running on (you can change the RAID while the system is on). In some of the cases those DOMs are used as standard installer media and it's getting installed to the RAID itself and booting from the RAID after the first install (you set up the raid at your first boot). FreeNAS preferably uses an USB stick.
Amahi is based on Fedora, so it's installed like your home os. Windows should be obvious. Zarafa is Ubuntu based.
My builds:
'Baldur' - Data Server - Build Log
'Hlin' - UTM Gateway Server - Build Log
