Think I just fried my power supply
2 minutes ago, Hermes said:Thank you everyone. I think the shock messed with my line of thinking. I double checked everything and I wanted to bridge the power pins manually in case my case's power button somehow failed for an unknown reason. And guess what? By fiddling around with all the dozens of SATA cables I accidentally knocked off the PWR_SW jumper. Uhmmm... yeah. Please DO humiliate me because it feels embarassing. At the same time, a huge weight is off my shoulders since I don't have to spend any more money after the initial upgrade.
Thank you for your radically fast assistance everyone. I believe my issue to be solved for now.
Although @lafrente brings up a good point. The system might run now in idle but what happens under CPU and GPU load? Is there a (preferably small sized) program that I can torture my GPU and CPU with for a tiny bit? From the top of my head I can only think of combining single pieces of software meant to stress test either one of the components...
Prime95 for cpu and Furmark works well if you want something Really brutal but a bit unrealistic. your best bet may just see if the games you play have a built in benchmark.
