Posted July 28, 2022 I'm looking to upgrade from a 3060 to a 3080(non Ti), I'm sure my current 550w isn't going to be enough, but how much do I really need? Current Specs: 3060(Non Ti) 2600x(OC'd to 4.0) Noctua NH D15 16gb 3600 (1) M.2 SSD (1) 200mm case fan (4) 140mm case fans Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 I usually reccommend a quality 850 watt psu for a 3080 for 100 guarantee that there won't be a power off due to transient spikes. Something like this would be a good option https://pcpartpicker.com/product/WxZzK8/msi-mpg-a-gf-850-w-80-gold-certified-fully-modular-atx-power-supply-mpg-a850gf Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 Run my 3090 with an evga 850. Only see 550 from the wall. Gpu isn’t fully utilized with the cpu being subpar. Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz Spare RIg Lian Li O11 AIR MINI, I7 4790K, Asus Maximus VI Extreme, G.Skill Ares 2400 32Gb, EVGA 1080ti, 1080sc 1070sc & 1060 SSC, EVGA 850GA, Acer KG251Q 1920x1080@240hz Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 Author 10 hours ago, Mick Naughty said: Run my 3090 with an evga 850. Only see 550 from the wall. Gpu isn’t fully utilized with the cpu being subpar. What CPU are you running? Maybe I can keep my 550w for a while and upgrade later. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 15 hours ago, FAHEYGF87 said: my current 550w What's the brand and model? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 13 minutes ago, FAHEYGF87 said: What CPU are you running? Maybe I can keep my 550w for a while and upgrade later. 9900k. Doubt a 550 has the amperage needed on the rail to support the card at anything more than idle. Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz Spare RIg Lian Li O11 AIR MINI, I7 4790K, Asus Maximus VI Extreme, G.Skill Ares 2400 32Gb, EVGA 1080ti, 1080sc 1070sc & 1060 SSC, EVGA 850GA, Acer KG251Q 1920x1080@240hz Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 In terms of minimum, I'd say a quality 850W that can handle the spikes properly. That said, I would probably at least get a 1000W just so you are in the higher part of the efficiency curve more during load + having a bit more wiggle room. But you don't have to do that. Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo Test Bench: CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850 Bench: Cooler Master Masterframe 700 (bench mode) Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2022 16 hours ago, FAHEYGF87 said: I'm looking to upgrade from a 3060 to a 3080(non Ti), I'm sure my current 550w isn't going to be enough, but how much do I really need? Current Specs: 3060(Non Ti) 2600x(OC'd to 4.0) Noctua NH D15 16gb 3600 (1) M.2 SSD (1) 200mm case fan (4) 140mm case fans Some 3080s draw more power than 3080 tis so it is best to get to know the difference in the cards. The range is from 320 to 400 watts stock so what card you pick may influence your PSU choice. I like these videos for comparing cards. I picked 1000 since I had issues with my 2080 tis and 850 PSUs. Using 1000 watt PSUs fixed the problem. I am sure that it was something to do with the motherboard, GPU combination but it was cheaper to replace the PSU than the other parts. RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090 | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
