5 minutes ago, Bogaa said:
https://at.pcpartpicker.com/list/x3VPQ6 is that AIO cooler an overkill?
id get a hyper 212 or a deepcool ak400, no point getting an overpriced 240 for an i5
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1445569-aio-cooler/#findComment-15496347
On 7/26/2022 at 1:22 PM, Origami Cactus said:
That is expensive for a 240mm rad. You sure you can't get an arctic 280mm for that price? They are really good and would work fine, even if you upgrade to i9 later.
I9 not so much they redline almost anything
Oh and op you really dont need that kryonaut it wont matter one bit
https://linustechtips.com/topic/1445569-aio-cooler/#findComment-15497979
